[mapguide-users] IIS 7.0 Forbidden when opening /mapguide/ (frombrowser and Maestro)
Bojan Franc at FER bojan.franc at fer.hr
Tue Feb 16 08:44:23 EST 2010
The suggested link http://server.ip/mapguide/mapagent/mapagent.fcgi gives
me...
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be
displayed.
I tought there was a problem with permissions reading the folder, but seems
that is not the case.
Do I have to "enable" fcgi in IIS configuration or something similar?
Regards,
    B. Franc
----- Original Message -----
From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
To: <mapguide-users at lists.osgeo.org>
Sent: Tuesday, February 16, 2010 12:40 PM
Subject: Re: [mapguide-users] IIS 7.0 Forbidden when opening /mapguide/
> Try entering the full url into Maestro:
> If you use the shorter version, Maestro will attempt to use that first,
> then try to append "mapagent/mapagent.fcgi",
> but if the second attempt also fails, you get the error from the short
> one.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> On 16-02-2010 10:30, BojanFranc at FER wrote:
>> Hi,
>> I was running MGOS with Apache so far, now want to use it with IIS.
>> A got a IIS configuration error somewhere, I think...
>> I can open MapAdmin and MapAgent with no problems.
>> http://server.ip/mapguide/mapadmin
>> ... redirects me to login.php and works OK...
>> ... works OK
>> But when I try to open http://server.ip/mapguide/ from browser or connect
>> from Maestro,
>> I get ...
>> 403 - Forbidden: Access is denied.
>> You do not have permission to view this directory or page using the
>> credentials that you supplied.
>> I am using IIS 7.0 on a Win2008 R2 server. It's a clean install, I only
>> changed some options in IIS to get PHP working.
>> What am I missing?
>> Regards,
>>   B. Franc
> mapguide-users mailing list
