[mapguide-users] Some thought on FDO PostGIS Provider
Jason Birch
jason at jasonbirch.com
Thu Feb 18 00:20:41 EST 2010
To the OP:
I understand your frusteration with getting PostGIS to work, but the
fact is that it's languishing because it hasn't had enough community
interest and development support. My organisation and Refractions
Research funded initial development of the provider by Mateusz, but it
never performed well enough to meet our needs. Following that, Geomap
GIS performed some bug fixes and maintenance. Apart from that there
has been very limited interest, funding, or development on this
provider. It looks like there may be some light at the end of the
tunnel now that Autodesk has resurrected and improved on a discarded
version of the initial provider, but you won't see benefit from that
until at least 2.2 if not later.
To follow up on Traian's point, it's quite possible that the required
GDAL and plugins are available in the OSGeo4W repository. The mapguide
trac page for the GDAL provider (linked from the front page I think)
links to a message showing how to add raster plugins. After some
initial encouragement from Frank, all it took was a half hour or so
sitting with "depends.exe" to work out what I needed in addition to
gdal.dlls. I'd imagine that vector/ogr plugins work the same way.
Jason
On 2010-02-17, Traian Stanev <traian.stanev at autodesk.com> wrote:
>> Why OGR is no more built by default with PostGIS support?
> It never was compiled with PostGIS by default. Before, I was doing a custom
> build with a static link to an OGR build which has PostGIS support built in.
> Needless to say that takes a long time to do due to the huge dependency list
> and there have only been one or two people who have asked for it, so not
> enough demand to make it worth my time.
> However, since the default build now uses dynamic link to the GDAL DLL, you
> should be able to replace the Gdal.dll with one that has PostGIS support
> compiled in it and automatically get PostGIS support.
>> That said, if you know an URL with OGR dll compiled with PostGIS
>> support, in a version compatible with Mapguide, I would rather try
>> them, before starting editing the 1000 layers...
> I only have such builds for FDO 3.3 (MG 1.2), posted at 13-9.com. If there
> is enough demand, I could try to do a build with whatever FDO the "new" MGOS
> is using -- but it would really be better if someone else who is more vested
> in this volunteered, and I could provide some support with how to build it.
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gabriele
> Monfardini
> Sent: Wednesday, February 17, 2010 6:48 AM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Some thought on FDO PostGIS Provider
> Hi all,
> I am trying Mapguide 2.1 and FDO PostGIS provider (using Maestro 2.0 RC1).
> The provider uses the word "datastore" to refer to PostgreSQL schema
> (http://www.postgresql.org/docs/current/interactive/ddl-schemas.html).
> This is very misleading since there are schemas and tablespaces in
> PostgreSQL, but no datastores.
> Moreover (this can be a Maestro issue) the default value seems to be
> empty instead of "public", that is the default schema present in all
> PostgreSQL databases.
> Second problem: what is the reason to include the schema in the
> dataconnection?
> I mean, I want to connect to a specific database, not to a specific
> schema inside the database.
> The schema and the table should be part of layer definition, as in OGR
> Provider.
> This would be better from a logic point of view and I don't know of
> any application that requires to specify the schema before connecting
> to a PostgreSQL db.
> One may think this is a minor issue.
> In fact it depends on the size of the repository.
> I'm about to migrate from Mapguide 1.2 OGR Provider to 2.1 PostGIS
> Provider.
> I have around 40 databases, each one with 5-10 schemas for a total of
> over 1000 layers.
> With Postgis Provider I have to create 200-400 dataconnection (instead
> of 40) and manually modify all 1000 layers.
> The last part is needed since the layer specifies in the FeatureName
> the dataconnection provider type (that has to be updated from
> OGRSchema:schema~table to FdoPostGIS:table) and from my preliminary
> experiments Maestro is not so smart to update the layers when I change
> only the dataconnection type, but not its name.
> I do not consider this a Maestro issue (in fact its smartness is
> already invaluable), but a not so smart decision when designing the
> XML schema.
> Since the layer specifies the ResourceId, IMHO there is no apparent
> need to decorate its FeatureName with dataconnection provider type.
> But maybe I'm ignoring something.
> I've also probably found a bug in FDO PostGIS provider.
> If at least one table in the schema contains a field of type
> "timestamp with time zone", the provider is not able to describe the
> schema.
> Trying to save such a dataconnection into the repository (with
> Maestro) or trying to create a layer with this dataconnection leads to
> errors in Mapguide 2.1.
> Not always the errors are the same (different paths in the code
> depending to resource already cached or not?), and I report the three
> more commons:
> 1 - "describe schema command failed" at
> mgdev\server\src\services\feature\ServerDescribeSchema.cpp, line 204
> <2010-02-15T18:06:59> 512 MapGuide Maestro
> v2.0.0.4569 10.1.1.244 Administrator
> Error: An exception occurred in FDO component.
> The describe schema command failed for 'FdoPostGIS' schema.
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation() line 83 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpDescribeSchemaAsXml.Execute() line 110 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
> - MgServerFeatureService.DescribeSchemaAsXml() line 333 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerFeatureService.cpp
> - MgServerDescribeSchema.DescribeSchemaAsXml() line 628 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
> - MgServerDescribeSchema.DescribeSchema() line 564 file
> - MgServerDescribeSchema.DescribeFdoSchema() line 204 file
> 2 - "Null reference" at
> \mgdev\server\src\services\feature\ServerDescribeSchema.cpp, line 77
> (not so auto-explaining message for the user)
> <2010-02-15T17:50:02> 2556 MapGuide Maestro
> Error: Null reference.
> StackTrace:
> - MgServerDescribeSchema.DescribeFdoSchema() line 77 file
> 3 - A terrible MgInvalidStreamHeaderException that seems not properly
> catched and crashes the server, without logging anything at all.
> This seems to happen more often when trying to create the layer
> selecting the dataconnection.
> This one appears to be a bug in Mapguide.
> I've also find a possible bug in Maestro.
> When I try to save the problematic dataconnection it warns me that FDO
> connection failed and offers to save it anyway. Sometimes, even if I
> save it, it does not record correctly the Datastore, leaving it empty
> in the XML.
> Last "rant".
> It would have provided me a much more smooth upgrade from 1.2.
> Moreover, FDO PostGIS Provider is quite recent, initially developed
> only for Windows, and I suspect not so much used.
> Having 2 possible connection to PostGIS would offer the possibilities
> to compare the performances (that in my situation are very important)
> and choose the best one.
> I am not so happy to drop here and there new dlls, also because in my
> experience MG is quite strict on library versions, and at least
> version 1.2 quite poor on logging useful information. So this could
> lead to not-logged crashes or generic errors that are very difficult
> to solve.
> Regards,
> Gabriele Monfardini
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
