[mapguide-users] RE: Mapguide Studio - Limititation to adding layers?
JamesDudden jamesdudden at blueyonder.co.uk
Thu Feb 18 07:35:03 EST 2010
Do you have that many layers on one map or that many layers in multiple
folders on one map. If the latter then you do have a lot of layers if not
then I have used more so you should be fine.
Have you added any scale ranges?
Are the layers initially displayed in the map?
Both these things can speed the map up.
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://n2.nabble.com/Mapguide-Studio-Limititation-to-adding-layers-tp4591337p4591479.html
