[mapguide-users] RE: GeoREST 1.0 Released!
Haris Kurtagic haris at sl-king.com
Thu Feb 18 16:42:10 EST 2010
It works for me.
You can run same sample locally on your desktop machine after you download
and unzip georest.
Haris
On Thu, Feb 18, 2010 at 10:29 PM, BradM <brad.mason at dfo-mpo.gc.ca> wrote:
>  Haris,  could you please check to see if your basic sample is working
> at:
> http://www.sl-king.com/georestsamples<https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html>
> /<https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html>
> example1<https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html>
> rview<https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html>
> .ht<https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html>
> ml<https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html>
> No map shows up for me for some reason/
> thanks
>  *Brad Mason M.R.M.*
> Senior Habitat Inventory Biologist
> Habitat Protection and Sustainable Development
> Oceans, Habitat and Enhancement Branch
> Fisheries and Oceans Canada
> 200 401 Burrard St.,
> Vancouver, B.C. Canada  V6C 3S4
> tel: (604)666-7015
> fax: (604)666-0417
> email: [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594472&i=0>
> *Director, Community Mapping Network*
> *www.cmnbc.ca* <http://www.cmnbc.ca/>
> *From:* Haris Kurtagic [via OSGeo.org] [mailto:[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594472&i=1>
> *Sent:* Thu 18/02/2010 12:26 PM
> *To:* Mason, Brad
> *Subject:* Re: GeoREST 1.0 Released!
> Yes, that is exactly what we are doing with GeoREST.
> There is working example with Sheboygan data, when you unpack GeoREST. As
> it says in installation notesÂ
> http://code.google.com/p/georest/wiki/Installation you can run it and try
> quickly with build-in http server. You can try it even without MapGuide  in
> such case there will be no image but you can view/edit data as vector trough
> OL and GeoREST OL layer.
> Also, on our web there is basic sample:
> http://www.sl-king.com/<http://www.sl-king.com/georestsamples/example1/rview.html>
> georestsamples <http://www.sl-king.com/georestsamples/example1/rview.html>
> / <http://www.sl-king.com/georestsamples/example1/rview.html>example1<http://www.sl-king.com/georestsamples/example1/rview.html>
> / <http://www.sl-king.com/georestsamples/example1/rview.html>rview<http://www.sl-king.com/georestsamples/example1/rview.html>
> .ht <http://www.sl-king.com/georestsamples/example1/rview.html>ml<http://www.sl-king.com/georestsamples/example1/rview.html>
> When you zoom  in , you can edit parcels, buildings. When you select
> parcel/building on left you will get option to click edit which will be
> bring html form trough which you can edit data.
> All this is driven trough http and html templates, you don't need any
> coding to do basic stuff.
> What is missing right now is security for editing.Â
> We are working on real project where edits needs to be allowed for
> authenticated users only, when we finish it it will be part of GeoREST.Â
> Haris
> On Thu, Feb 18, 2010 at 8:55 PM, BradM <[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594141&i=0>
> > wrote:
>> Hello, Â could you please give me an example using GeoREST, Â where users
>> can
>> digitize a point, line or polygon, and then bring up an html data entry
>> form. Â  Â The user can then add data to the data entry form and send it
>> and
>> the associated coordinates to a database. Â The database can then be
>> searched
>> and reports created.. Is this a good use of GeoREST?
>> thanks
>> View this message in context:
>> http://n2.nabble.com/GeoREST-1-0-Released-tp4212935p4593986.html
>>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594141&i=1>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594141&i=2>
> View this message in context: RE: GeoREST 1.0 Released!<http://n2.nabble.com/GeoREST-1-0-Released-tp4212935p4594472.html>
> Sent from the MapGuide Users mailing list archive<http://n2.nabble.com/MapGuide-Users-f1803227.html>at Nabble.com.
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100218/22478876/attachment.html
