[mapguide-users] Re: Is it Possible to set Feature Label for
a layer dynamically
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Feb 19 03:03:16 EST 2010
http://lists.osgeo.org/pipermail/mapguide-users/2009-January/016165.html
Yes, it is in PHP.
Given that you have asked for this numerous times, and had no response,
its very likely that no one has what you are asking for.
Using the above link, you can see what you need to do, but in php.
You will have to convert that to C# yourself.
When you are done, it would be nice if you would share your work:
http://trac.osgeo.org/mapguide/wiki/CodeSamples
Unfortunately, not many people write up samples, which is why there is no
sample for what you want to do.
I find it strange that you have not mentioned the API documentation yet.
Try this link:
http://mapguide.osgeo.net/files/mapguide/docs/webapi/d6/de2/class_mg_layer.html
Regards, Kenneth Skovhede, GEOGRAF A/S
On 19-02-2010 08:21, SriRam007 wrote:
> Can u please post the exact link
> I went through all the link but still not getting anything which will be
> useful for me.
> I am using C#.Net and Javascript but some links are in PHP and some
> diffeerent topic are also comming
> i did not get which one should i use and which should be my first step
> Here below i m describing my requirement ::
> My map is having so many layers like (L1,L2,L3)
> so like featrues F1,F2,F3
> And each feature of a layer is having some property like {F1 : (P1,P2,P3)
> ,F2 : (P4,P5,P6) ,F3 : (P7,P8)}
> and one of them already i set as feature label
> eg: for "F1" layer "P2" property is there as feature label But i want to
> change it to "P3" at runtime only.
> and for all feature of a layer ie layer wise
> Please guide me anyone
> thanks
> http://n2.nabble.com/file/n4596494/Set_Label_Feature.bmp :confused:
