[mapguide-users] Re: Is it Possible to set Feature Label for a layer dynamically
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Feb 19 06:51:16 EST 2010
If you look at the second link (to the documentation),
the method "SetLayerDefinition" can make the layer point to another
resource.
As with the first example, you need to make a copy of the
LayerDefinition xml.
If you just modify the LayerDefinition xml without making a copy, the change
will be visible for all users, current and future.
Basic steps are:
1) Obtain the MgMap instance
2) Find the layer
3) Load the LayerDefinition xml (link 1)
4) Modify the FeatureLabel (link 1)
5) Save a copy of the LayerDefinition xml (link 1)
6) Make the layer from step 2 point to the copy of the LayerDefinition
from step 5 (link 2)
7) Save the MgMap instance from step 1
8) Refresh the map on the client (developer guide)
steps 1,2 and 7 have hints in the developer guide, but are
also avalible in the API documentation under MgMap.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 19-02-2010 10:41, SriRam007 wrote:
> ave given are for a new layer which is working fine and
> I got some help from Buffer.aspx page.
> But
> I want to change feature label for an existing layer.
> The layer is having 3 fields like (Id,Name,Adress)
> Currently its showing Id in the map. But i want to change it to name
> Is there any way to do so...
