[mapguide-users] Re: SetSelectionXML Problem (Selection and Zoom to selected Feature)
Nickthetemp nickthetemp at gmail.com
Fri Feb 19 14:18:16 EST 2010
Here is how I achieve  what you are trying to do in php.
Here is my javascript function:
function CellClicked(sel)
    parent.parent.mapFrame.SetSelectionXML(sel);
    parent.parent.mapFrame.ExecuteMapAction(10);
This is my php stuff
Initialize Mapguide:
      MgInitializeWebTier ($webconfigFilePath);
      $userInfo = new MgUserInformation($sessionId);
      $siteConnection = new MgSiteConnection();
      $siteConnection->Open($userInfo);
      $resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
      $featureSrvc =
$siteConnection->CreateService(MgServiceType::FeatureService);
      $map = new MgMap($siteConnection);
      $map->Open($resourceService, $mapName);
Then you have to set up your query in order to get the item you want to
select:
In this case I am querying a unique number. (number is a column in my
feature table that I am searching)
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetFilter("number = $number "); <-----------enter your search
criteria here
I then get the layer I want to query and select the feature based on the
query set previous:
$layer = $map->GetLayers()->GetItem('Business'); <-------Enter you layer
name here
$featureReader = $layer->SelectFeatures($queryOptions);
I then set the selection and change it to a xml, and EscapeForHtml.
$selection = new MgSelection($map);
$selection->AddFeatures($layer, $featureReader, 1);
$selectionXml = $selection->ToXml();
$selectionXml = EscapeForHtml($selectionXml, true);
Then I send the selectionxml to my function. In order to do this I use a
little trick. Since I want my function to be called automatically when the
script runs I have a 1by1.gif image which is  located in the same place as
my script. I then echo the image and call my function in the image load:
Note: the image is just a blank 1 x 1 pixel image which is not visable.
echo " 1by1.gif ";  <--xxxxxx = onload - had to remove for fourm rules
In this Script I am calling it from the task page.
I have the user select a number from a dropdown list.
this number is then passes to my script as the query number.
Hope this gives you some help
View this message in context: http://n2.nabble.com/SetSelectionXML-Problem-Selection-and-Zoom-to-selected-Feature-tp4585892p4599603.html
