[mapguide-users] Problem with KingOracle and SpatialFilter using
CurvePolygon
Haris Kurtagic
haris at sl-king.com
Fri Feb 19 16:33:41 EST 2010
Fix is in trunk now. I have added unittest for that case and it seems it
works fine now.
Problem and fix was exactly as you described. numrings--; line was copied
from standard polygon conversion were exterior ring was done separately.
Thank you.
Haris
On Fri, Feb 19, 2010 at 5:30 PM, Andreas Morf <a.morf at fkl.ch> wrote:
> Haris,
> found the bug: #617
> Seems that nobody used curved polygons so far with KingOracle: bug is a
> blocker for all curved polygons resulting in a null-geometry...
> Andreas
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100219/b5421175/attachment.html
