[mapguide-users] Re: Problem with Studio 2010 +Flexible layouts Error
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Feb 23 03:35:21 EST 2010
It sounds as if your bounds are incorrect? (on the MapDefinition you can
set the bounds).
You could also have a problem with mismatch between the FeatureSource
coordinate system,
and map coordinate system.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 23-02-2010 06:01, padmini godavarthi wrote:
> Hi mark,
> Thanku very much for your reply........
> can u plz clarify some of my doubts....
> 1) After clicking "show in browser" i got a map posted previously.After
> Zooming the map may times it comes to original data .I have set the
> coordinate system in my map definition is
> UTM83-11 (UTM with NAD83 datum, Zone 11, Meter; Central Meridian 117d W)
> which is correct to my shape file.
> and my application defintion is
> <?xml version="1.0" encoding="UTF-8"?>
> <ApplicationDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
> * MapSet
> * Contains the map(s) you want available to your
> * application.
>   <MapSet>
>       <MapGroup id="layer">
>         <Map>
>           <Type>MapGuide</Type>
>           <SingleTile>true</SingleTile>
>           <Extension>
>             <ResourceId>Library://state/layer.MapDefinition</ResourceId>
>             <SelectionAsOverlay>true</SelectionAsOverlay>
>             <SelectionColor>0x0000FFA0</SelectionColor>
>           </Extension>
>         </Map>
>         <Extension />
>       </MapGroup>
>    </MapSet>
> * WidgetSet
> * Contains the widgets you want available to your
> * application.
>    <WidgetSet xsi:type="WidgetSetType">
> * ContextMenu (Tasks)
> * Menu available to the Task Pane
>      <Container xsi:type="UiItemContainerType">
>        <Name>TaskContextMenu</Name>
>        <Type>ContextMenu</Type>
>        <Item xsi:type="WidgetItemType">
>          <Function>Widget</Function>
>          <Widget>menuMeasure</Widget>
>        </Item>
>          <Widget>menuBuffer</Widget>
>        </Item>
>      </Container>
> * ContextMenu (Map)
> * Menu available to the Map on right-click
>        <Name>MapContextMenu</Name>
>          <Widget>menuRefreshMap</Widget>
>        </Item>
>        <Item xsi:type="SeparatorItemType">
>          <Function>Separator</Function>
>        </Item>
>          <Widget>menuPan</Widget>
>        </Item>
>          <Widget>menuZoomInRectangle</Widget>
>        </Item>
>        </Item>
>          <Widget>menuZoomInFixed</Widget>
>        </Item>
>          <Widget>menuZoomOutFixed</Widget>
>        </Item>
>        </Item>
>        <Item xsi:type="FlyoutItemType">
>          <Function>Flyout</Function>
>          <Label>Zoom</Label>
>          <Tooltip>Open the zoom menu</Tooltip>
>          <ImageUrl/>
>          <ImageClass/>
>            <Widget>menuInitialMapView</Widget>
>          </Item>
>            <Widget>menuPreviousView</Widget>
>          </Item>
>            <Widget>menuNextView</Widget>
>          </Item>
>            <Widget>menuInitialMapScaleAndCenter</Widget>
>          </Item>
>            <Widget>menuZoomSelection</Widget>
>          </Item>
>        </Item>
>        </Item>
>          <Widget>menuSelect</Widget>
>        </Item>
>          <Widget>menuClearSelection</Widget>
>        </Item>
>          <Label>Select More</Label>
>          <Tooltip>Open the select menu</Tooltip>
>          <ImageUrl/>
>          <ImageClass/>
>            <Widget>menuSelectRadius</Widget>
>          </Item>
>            <Widget>menuSelectPolygon</Widget>
>          </Item>
>            <Widget>menuSelectWithin</Widget>
>          </Item>
>        </Item>
>        </Item>
>        </Item>
>        </Item>
>        </Item>
>          <Widget>menuViewOptions</Widget>
>        </Item>
>        </Item>
>          <Widget>menuHelp</Widget>
>        </Item>
>          <Widget>menuAbout</Widget>
>        </Item>
>      </Container>
> * Toolbar (Primary)
>        <Name>Toolbar</Name>
>        <Type>Toolbar</Type>
>          <Widget>toolbarHelp</Widget>
>        </Item>
>          <Widget>toolbarAbout</Widget>
>        </Item>
>          <Widget>toolbarViewOptions</Widget>
>        </Item>
>          <Widget>GetPrintablePage</Widget>
>        </Item>
>        </Item>
>          <Widget>toolbarSelectRadius</Widget>
>        </Item>
>          <Widget>toolbarSelectPolygon</Widget>
>        </Item>
>          <Widget>toolbarSelectWithin</Widget>
>        </Item>
>          <Widget>toolbarClearSelection</Widget>
>        </Item>
>        </Item>
>          <Widget>toolbarMeasure</Widget>
>        </Item>
>          <Widget>toolbarBuffer</Widget>
>        </Item>
>        </Item>
>          <Widget>toolbarRefreshMap</Widget>
>        </Item>
>      </Container>
> * Toolbar (Secondary)
>        <Name>ToolbarSecondary</Name>
>          <Widget>Select</Widget>
>        </Item>
>          <Widget>Pan</Widget>
>        </Item>
>        </Item>
>          <Widget>ZoomInRectangle</Widget>
>        </Item>
>          <Widget>ZoomInFixed</Widget>
>        </Item>
>          <Widget>ZoomOutFixed</Widget>
>        </Item>
>        </Item>
>          <Widget>toolbarSecondaryInitialMapView</Widget>
>        </Item>
>          <Widget>toolbarSecondaryPreviousView</Widget>
>        </Item>
>          <Widget>toolbarSecondaryNextView</Widget>
>        </Item>
>        </Item>
>          <Widget>toolbarSecondaryZoomSelection</Widget>
>        </Item>
>      </Container>
> * File Menu
> * File Menu at the top of the application.
>        <Name>FileMenu</Name>
>            <Widget>MapMenu</Widget>
>          </Item>
>          <Label>View</Label>
>          <Tooltip/>
>          <ImageUrl/>
>          <ImageClass/>
>            <Widget>showOverviewMap</Widget>
>          </Item>
>        </Item>
>          <Label>Tasks</Label>
>          <Tooltip/>
>          <ImageUrl/>
>          <ImageClass/>
>            <Widget>menuPlaceholder</Widget>
>          </Item>
>        </Item>
>      </Container>
> * Statusbar (Status Bar)
>        <Name>Statusbar</Name>
>        <Type>Splitterbar</Type>
>          <Widget>StatusCoords</Widget>
>        </Item>
>          <Widget>StatusSelection</Widget>
>        </Item>
>          <Widget>StatusScale</Widget>
>        </Item>
>          <Widget>StatusViewSize</Widget>
>        </Item>
>      </Container>
> * Placeholder Widget
>      <Widget xsi:type="WidgetType">
>        <Name>menuPlaceholder</Name>
>        <Type>InvokeScript</Type>
>        <StatusItem/>
>        <Extension>
>          <Script>return true</Script>
>        </Extension>
>        <ImageUrl/>
>        <ImageClass/>
>        <Tooltip/>
>        <Label>menu item</Label>
>        <Disabled/>
>      </Widget>
> <!-- MAP -->
>      <MapWidget xsi:type="WidgetType">
>        <Name>Map</Name>
>        <Type>Map</Type>
>        <StatusItem>The map.</StatusItem>
>        <Extension xsi:type="CustomContentType">
>          <MenuContainer>MapContextMenu</MenuContainer>
>          <!--Scales>100000,50000,25000,12500,8000,4000</Scales-->
>        </Extension>
>        <MapId>sheboygan</MapId>
>      </MapWidget>
> * Context Menu - Widgets
> * Widgets belonging to the map context menu
> <!-- CONTEXT MENU PAN -->
>      <Widget xsi:type="UiWidgetType">
>        <Name>menuPan</Name>
>        <Type>Pan</Type>
>        <StatusItem>Drag the map to view areas out of range.</StatusItem>
>        <ImageUrl>images/icons.png</ImageUrl>
>        <ImageClass>pan</ImageClass>
>        <Tooltip>Pan mode</Tooltip>
>        <Label>Pan</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU ZOOM RECTANGLE -->
>        <Name>menuZoomInRectangle</Name>
>        <Type>Zoom</Type>
>        <StatusItem>Zoom in on an area.</StatusItem>
>          <Tolerance>5</Tolerance>
>          <Factor>2</Factor>
>        </Extension>
>        <ImageClass>zoom-in</ImageClass>
>        <Tooltip>Zoom In</Tooltip>
>        <Label>Zoom Rectangle</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU ZOOM FIXED (IN) -->
>        <Name>menuZoomInFixed</Name>
>        <Type>ZoomOnClick</Type>
>        <StatusItem>Zoom in by a preset increment.</StatusItem>
>          <Factor>2</Factor>
>        </Extension>
>        <ImageClass>zoom-in-fixed</ImageClass>
>        <Label>Zoom In</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU REFRESH MAP -->
>        <Name>menuRefreshMap</Name>
>        <Type>RefreshMap</Type>
>        <StatusItem>Refreshes the map image.</StatusItem>
>        <ImageClass>view-refresh</ImageClass>
>        <Tooltip>Refresh map and reload all layers, keeping the current center
> point and scale.</Tooltip>
>        <Label>Refresh Map</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU ZOOM FIXED (OUT) -->
>        <Name>menuZoomOutFixed</Name>
>        <StatusItem>Zoom out by a preset increment</StatusItem>
>          <Factor>0.5</Factor>
>        </Extension>
>        <ImageClass>zoom-out-fixed</ImageClass>
>        <Tooltip>Zoom Out</Tooltip>
>        <Label>Zoom Out</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU INITIAL MAP VIEW -->
>        <Name>menuInitialMapView</Name>
>        <Type>InitialMapView</Type>
>        <StatusItem>Fit the extents of the map to the window</StatusItem>
>          <ViewType>extent</ViewType>
>        </Extension>
>        <ImageClass>zoom-full</ImageClass>
>        <Tooltip>Initial Map View</Tooltip>
>        <Label>Initial Map View</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU PREVIOUS VIEW -->
>        <Name>menuPreviousView</Name>
>        <Type>ExtentHistory</Type>
>        <StatusItem>Go to previous view.</StatusItem>
>          <Direction>previous</Direction>
>        </Extension>
>        <ImageClass>view-back</ImageClass>
>        <Tooltip>Previous View</Tooltip>
>        <Label>View Previous</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU NEXT VIEW -->
>        <Name>menuNextView</Name>
>        <StatusItem>Go to next view.</StatusItem>
>          <Direction>next</Direction>
>        </Extension>
>        <ImageClass>view-forward</ImageClass>
>        <Tooltip>Next View</Tooltip>
>        <Label>View Next</Label>
>        <Disabled/>
>      </Widget>
>        <Name>menuInitialMapScaleAndCenter</Name>
>        <StatusItem>Zoom to initial map center and scale.</StatusItem>
>          <ViewType>center</ViewType>
>        </Extension>
>        <Tooltip>Initial Map Center and Scale</Tooltip>
>        <Label>Initial Center and Scale</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU ZOOM SELECTION -->
>        <Name>menuZoomSelection</Name>
>        <Type>ZoomToSelection</Type>
>        <StatusItem>Zoom to the extents of the current selection.</StatusItem>
>        <ImageClass>select-zoom</ImageClass>
>        <Tooltip>Zoom to selection.</Tooltip>
>        <Label>Zoom Selection</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU SELECT -->
>        <Name>menuSelect</Name>
>        <Type>Select</Type>
>        <StatusItem>Select features by clicking and dragging.</StatusItem>
>        <ImageClass>select-features</ImageClass>
>        <Tooltip>Select mode</Tooltip>
>        <Label>Select mode</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU CLEAR SELECTION -->
>        <Name>menuClearSelection</Name>
>        <Type>ClearSelection</Type>
>        <StatusItem>Clears the current selection.</StatusItem>
>        <ImageClass>select-clear</ImageClass>
>        <Tooltip/>
>        <Label>Clear Selection</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU SELECT RADIUS -->
>        <Name>menuSelectRadius</Name>
>        <Type>SelectRadius</Type>
>        <StatusItem>Click and drag to select all features inside a
> circle.</StatusItem>
>        <ImageClass>select-radius</ImageClass>
>        <Tooltip>Select Radius</Tooltip>
>        <Label>Select Radius</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU SELECT POLYGON -->
>        <Name>menuSelectPolygon</Name>
>        <Type>SelectPolygon</Type>
>        <StatusItem>Create a polygon and select all features that fall
> within.</StatusItem>
>        <ImageClass>select-polygon</ImageClass>
>        <Tooltip>Select Polygon</Tooltip>
>        <Label>Select Polygon</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU SELECT WITHIN -->
>        <Name>menuSelectWithin</Name>
>        <Type>SelectWithin</Type>
>        <StatusItem>Select all features that fall within the currently
> selected area.</StatusItem>
>        <ImageClass>select-within</ImageClass>
>        <Tooltip>Select Within</Tooltip>
>        <Label>Select Within</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU BUFFER -->
>        <Name>menuBuffer</Name>
>        <Type>BufferPanel</Type>
>        <StatusItem>Create buffers around the selected features</StatusItem>
>        <ImageClass>buffer</ImageClass>
>        <Tooltip>Buffer</Tooltip>
>        <Label>Buffer</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU  VIEW OPTIONS -->
>        <Name>menuViewOptions</Name>
>        <Type>ViewOptions</Type>
>        <StatusItem>Switch between Imperial and Metric units</StatusItem>
>          <DisplayUnits>degrees</DisplayUnits>
>        </Extension>
>        <ImageClass>view-options</ImageClass>
>        <Tooltip/>
>        <Label>View Options</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU HELP -->
>        <Name>menuHelp</Name>
>        <Type>Help</Type>
>        <StatusItem/>
>        <ImageClass>help</ImageClass>
>        <Tooltip/>
>        <Label>Help</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU ABOUT -->
>        <Name>menuAbout</Name>
>        <Type>About</Type>
>        <StatusItem/>
>        <ImageUrl/>
>        <ImageClass/>
>        <Tooltip/>
>        <Label>About</Label>
>        <Disabled/>
>      </Widget>
> <!-- CONTEXT MENU MEASURE -->
>        <Name>menuMeasure</Name>
>        <Type>Measure</Type>
>        <StatusItem>Measure distances on the map.</StatusItem>
>          <Type>both</Type>
>          <MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
>          <MeasureTooltipType>dynamic</MeasureTooltipType>
>          <DistancePrecision>0</DistancePrecision>
>          <AreaPrecision>0</AreaPrecision>
>          <Units>meters</Units>
>          <Target>TaskPane</Target>
>        </Extension>
>        <ImageClass>measure</ImageClass>
>        <Label>Measure</Label>
>        <Disabled/>
>      </Widget>
> <!-- FILE MENU LAUNCH NAVIGATOR -->
>        <Name>showOverviewMap</Name>
>        <StatusItem/>
>        <Extension>
>          <Script>showOverviewMap()</Script>
>        </Extension>
>        <ImageUrl>images/icons/iconNavigator.png</ImageUrl>
>        <ImageClass/>
>        <Tooltip>Launch Overview Map</Tooltip>
>        <Label>Launch Overview Map</Label>
>        <Disabled/>
>      </Widget>
> * Toolbar - Widgets
> * Widgets belonging to the main toolbar
> <!-- TOOLBAR BUFFER -->
>        <Name>toolbarBuffer</Name>
>        <Extension>
>        </Extension>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR REFRESH MAP -->
>        <Name>toolbarRefreshMap</Name>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR MEASURE -->
>        <Name>toolbarMeasure</Name>
>          <Type>both</Type>
>        </Extension>
>        <Tooltip>Measure</Tooltip>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR VIEW OPTIONS -->
>        <Name>toolbarViewOptions</Name>
>          <DisplayUnits>meters</DisplayUnits>
>        </Extension>
>        <Tooltip/>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR HELP -->
>        <Name>toolbarHelp</Name>
>        <Type>Help</Type>
>        <StatusItem/>
>        <Tooltip/>
>        <Label></Label>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR ABOUT -->
>        <Name>toolbarAbout</Name>
>        <Type>About</Type>
>        <StatusItem/>
>        <ImageUrl/>
>        <ImageClass/>
>        <Tooltip/>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR CLEAR SELECTION -->
>        <Name>toolbarClearSelection</Name>
>        <Tooltip/>
>        <Label></Label>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR SELECT RADIUS -->
>        <Name>toolbarSelectRadius</Name>
>        <Label></Label>
>        <Disabled/>
>      </Widget>
> <!-- TOOLBAR SELECT POLYGON -->
>        <Name>toolbarSelectPolygon</Name>
>        <Label></Label>
>        <Disabled/>
>      </Widget>
> * Secondary toolbar - Widgets
> * Widgets belonging to the secondary toolbar
> <!-- SECONDARY TOOLBAR INITIAL MAP VIEW -->
>        <Name>toolbarSecondaryInitialMapView</Name>
>        </Extension>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- SECONDARY TOOLBAR PREVIOUS VIEW-->
>        <Name>toolbarSecondaryPreviousView</Name>
>        </Extension>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- SECONDARY TOOLBAR NEXT VIEW -->
>        <Name>toolbarSecondaryNextView</Name>
>        </Extension>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- SECONDARY TOOLBAR ZOOM SELECTION -->
>        <Name>toolbarSecondaryZoomSelection</Name>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- SECONDARY TOOLBAR SELECT WITHIN -->
>        <Name>toolbarSelectWithin</Name>
>        <ImageUrl>images/icons/select-features.png</ImageUrl>
>        <Extension>
>        </Extension>
>        <ImageClass/>
>        <Label></Label>
>        <Disabled/>
>      </Widget>
> * Status Bar - Widgets
> * Widgets belonging to the status bar
> <!-- STATUS POSITION -->
>        <Name>StatusCoords</Name>
>        <Type>CursorPosition</Type>
>        <StatusItem/>
>          <Template>X: {x} {units}, Y: {y} {units}</Template>
>          <Precision>4</Precision>
>          <EmptyText>&amp;nbsp;</EmptyText>
>        </Extension>
>      </Widget>
> <!-- STATUS SELECTION INFO -->
>        <Name>StatusSelection</Name>
>        <Type>SelectionInfo</Type>
>        <StatusItem/>
>        <Extension>
>            <EmptyText>No selection.</EmptyText>
>       </Extension>
>      </Widget>
> <!-- STATUS SCALE -->
>        <Name>StatusScale</Name>
>        <Type>EditableScale</Type>
>        <StatusItem/>
>      </Widget>
> <!-- STATUS VIEWSIZE -->
>        <Name>StatusViewSize</Name>
>        <Type>ViewSize</Type>
>        <StatusItem/>
>          <Template>{w} x {h} ({units})</Template>
>          <Precision>2</Precision>
>        </Extension>
>      </Widget>
> * Panels - Widgets
> <!-- LEGEND -->
>        <Name>Legend</Name>
>        <Type>Legend</Type>
>        <StatusItem/>
>      </Widget>
> <!-- SELECTION -->
>        <Name>SelectionPanel</Name>
>        <Type>SelectionPanel</Type>
>        <StatusItem/>
>      </Widget>
> <!-- TASKS -->
>        <Name>TaskPane</Name>
>        <Type>TaskPane</Type>
>        <StatusItem/>
>        <Extension>
>          <MenuContainer>TaskContextMenu</MenuContainer>
>        </Extension>
>      </Widget>
> * Misc - Widgets
> <!-- INMAP NAVIGATOR -->
>        <Name>Navigator</Name>
>        <Type>Navigator</Type>
>        </Extension>
>      </Widget>
> <!-- ZOOM IN RECTANGLE -->
>        <Name>ZoomInRectangle</Name>
>        <Type>Zoom</Type>
>          <Factor>2</Factor>
>        </Extension>
>        <Tooltip>Zoom in to a rectangular region.</Tooltip>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- ZOOM ON CLICK (IN) -->
>        <Name>ZoomInFixed</Name>
>          <Factor>4</Factor>
>        </Extension>
>        <Tooltip>Zoom in by a fixed factor.</Tooltip>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- ZOOM ON CLICK (OUT) -->
>        <Name>ZoomOutFixed</Name>
>        </Extension>
>        <Tooltip>Zoom Out by a fixed factor</Tooltip>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- SELECT -->
>        <Name>Select</Name>
>        <Type>Select</Type>
>        <Label/>
>        <Disabled/>
>      </Widget>
> <!-- MAPMENU -->
>      <Widget>
>        <Name>MapMenu</Name>
>        <Type>MapMenu</Type>
>        <StatusItem/>
>        <Extension/>
>        <ImageUrl/>
>        <ImageClass/>
>        <Tooltip/>
>        <Label>Maps</Label>
>        <Disabled/>
>      </Widget>
> <!-- OVERVIEW MAP -->
>        <Name>OverviewMap</Name>
>        <Type>OverviewMap</Type>
>        <Description/>
>        </Extension>
>      </Widget>
> <!-- PRINT -->
>        <Name>GetPrintablePage</Name>
>        <Type>Print</Type>
>        <StatusItem>Get printer-friendly page.</StatusItem>
>          <ShowPrintUI>true</ShowPrintUI>
>          <ShowTitle>true</ShowTitle>
>          <PageTitle>Some Title</PageTitle>
>          <ShowLegend>true</ShowLegend>
>          <ShowNorthArrow>true</ShowNorthArrow>
>          <ImageBaseUrl>images/</ImageBaseUrl>
>        </Extension>
>        <ImageClass>file-print</ImageClass>
>        <Tooltip>Get printable page.</Tooltip>
>        <Label></Label>
>        <Disabled/>
>      </Widget>
> <!-- PAN -->
>        <Name>Pan</Name>
>        <Type>Pan</Type>
>        <Label/>
>        <Disabled/>
>      </Widget>
>        <Name>Scalebar</Name>
>        <Type>ScalebarDual</Type>
>      </Widget>
>        <Name>MapTip</Name>
>        <Type>Maptip</Type>
>        <Extension>
>          <Label>Map Tips</Label>
>          <Delay>350</Delay>
>          <Layer>Parcels</Layer>
>        </Extension>
>      </Widget>
>    </WidgetSet>
>    <Extension/>
> </ApplicationDefinition>
> is there any modifications required??????????????
> 2)And i have create one flexible layout by taking slate flexible layout as a
> sampe.but it didn't apper in MG studio..Is there any chages required to
> display it in MG studio.I have refresh MG studio but of no use.............
> Regards,
> Padmini.
