[mapguide-users] Re: Is it Possible to set Feature Label for
a layer dynamically
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Feb 23 08:00:03 EST 2010
The change should be "permanent" until the end of the session (eg. press
F5 or similar).
If you want every new session to use the label,
you have to modify the MapDefinition to use the modified layer.
In this case, it is easiest to simply modify the LayerDefinition Xml.
Open, modify, save.
When you modify the LayerDefinition xml directly, all current users
will see the change after a map redraw, as well as all new users.
IMO, it is confusing if the display changes without the user doing anything.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 23-02-2010 13:03, SriRam007 wrote:
> changing the feature label but temporarly.
> Can't we make it permanently.
