[mapguide-users] Re: Unable to view-Mark
padmini godavarthi godavarthi.padmini at gmail.com
Wed Feb 24 01:09:53 EST 2010
Hi mark,
i have changed the ApplicationDefinition.xml as per your suggestions....but
the problem is same...
<?xml version="1.0"?>
<ApplicationDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
  <TemplateUrl>fusion/templates/mapguide/padmini/index.html</TemplateUrl>
  <MapSet>
    <MapGroup id="map">
      <Map>
        <Type>MapGuide</Type>
        <SingleTile>true</SingleTile>
        <Extension>
         <ProjectionCode>EPSG:26911</ProjectionCode>
        <ProjectionDef>+proj=utm +zone=11 +ellps=GRS80 +datum=NAD83 +units=m
+no_defs</ProjectionDef>
          <ResourceId>Library://flexisample1/map1.MapDefinition</ResourceId>
          <SelectionAsOverlay>true</SelectionAsOverlay>
          <SelectionColor>0x0000FFA0</SelectionColor>
        </Extension>
      </Map>
      <Extension />
    </MapGroup>
  </MapSet>
  <WidgetSet>
my data is zoomed  out (almost as a single point) in the browser.
After zooming In iam able to see the map...but the feature is not
selecting.............
In feature resource also  the coordinate system is
UTM83-11 (UTM with NAD83 datum, Zone 11, Meter; Central Meridian 117d W)
In Map definition also
In Application Definition also
then what might be the problem???????????
http://n2.nabble.com/file/n4623972/error.jpg
plz see the screen shot once...................
View this message in context: http://n2.nabble.com/Unable-to-view-Mark-tp4623889p4623972.html
