[mapguide-users] RE: Unable to view-Mark
Mark Pendergraft
markp at Meadgilman.com
Wed Feb 24 10:44:19 EST 2010
Padmini,
First off, Ivan did give you the answer you were looking for. The "Let me
google that for you" link returned several pages which i found very helpful
on what subversion and the trunk are. You should go back and revisit it if
you have questions about it.
I think the issue here is that you have loaded a 'custom' projection into
your Map resource. Using your definition, and the EPSG code i provided, I
had the same issue as you. The map was tiny. I realize that UTM Nad 83
Zone 11 is a pretty standard projection, but i think you have defined it in
a way that MapGuide thinks it's a custom projection. However i was able to
fix it by doing the following:
Open MapGuide Studio.
Open your map resource.
Click the button to the right of Coordinate System.
pull down the categories bar to "UTM, NAD83 Datum"
In the available coordinate systems, select the code UTM83-11
press ok
save your map resource.
you could also do the same in Maestro:
Open Maestro
Select Type EPSG code and type 26911.
press validate.
press ok.
-Mark
View this message in context: http://n2.nabble.com/Unable-to-view-Mark-tp4623889p4626559.html
