[mapguide-users] Re: MgApplicationException: Cannot create any
more connections to the OSGeo.SDF FDO provider
Zac Spitzer
zac.spitzer at gmail.com
Thu Feb 25 11:03:15 EST 2010
if you need to also update say SHP, just duplicate the providers.xml entry
and call it say OSGeo.SHP.ReadOnly etc
On Fri, Feb 26, 2010 at 2:57 AM, Dave Wilson <dave.wilson at autodesk.com> wrote:
> In the serverconfig.ini you need to be looking at the ConnectionPool settings in the FeatureServices section:
> DataConnectionPoolSize = 200
> DataConnectionPoolExcludedProviders = OSGeo.SDF,OSGeo.SHP
> The above are the defaults. If SDF or SHP is excluded you are only allowed one connection at a time. If you remove either or both then you can maintain multiple connections. You normally exclude them if you plan to update SDF or SHP via the API. If you don't then you can remove the DataConnectionPoolExcludedProviders entries.
> Use the Web Tier Test pages http://localhost/mapguide/mapagent/index.html and under Feature select GetFdoCacheInfo and this will show you how many connections are being made.
> Regards,
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of vittorio
> Sent: Thursday, February 25, 2010 3:04 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Re: MgApplicationException: Cannot create any more connections to the OSGeo.SDF FDO provider
> I looked at the file serverconfig.ini, what values do you mean?
> The map is displayed quickly enough, the problem occurs about after two
> hours when at most there are four concurrent connections
> View this message in context: http://n2.nabble.com/MgApplicationException-tp4626154p4631572.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
