[mapguide-users] Layer not showing
Jason Birch jason at jasonbirch.com
Thu Feb 25 21:44:17 EST 2010
Are the other layers in the map in the same projection as the raster?
Try starting a new map and adding the raster as the first layer and
see what happens.
Is it possible that there is another layer higher in the draw order
that is blocking the raster layer?
If you could post the xml of your raster data source, config file (if
any) and the map that might be useful.
Jason
On 2010-02-25, pilchid <m.phillips at theparkstrust.com> wrote:
> Hello
> Could someone please help - Im at my wits end. I have this ECW raster which
> has been connected to and built a layer from. It all seems fine and the
> layer itself previews great. When I add it to my map however - it just
> doesnt appear. It doesnt crach the map as everything else is just as it was.
> The layer is in the layers task pane. Just no where to be seen on the actual
> map. I have loaded it fine into my other gis software so I know its not a
> problem with coordinates.
> Can someone please help me.....
> Matt
> http://n2.nabble.com/Layer-not-showing-tp4633148p4633148.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
