[mapguide-users] Re: Using Mapguide OS with OpenLayers Setting
Layer Visibility
Pietro Ianniello
pietro.ianniello at gmail.com
Fri Feb 26 12:43:48 EST 2010
Dear Mike,
unfortunally I don't speak PHP!
...have not yet used Fusion, but is really good looking!... seems rather
complex... I know OL [I used it with Mapserver + WMS], so was a logic
choise... don't know how to get map layers' legend yet... if you can give a
simple example it would be great... even in PHP, I can read PHP code...
Dear durr,
OL = OpenLayers, MG = MapGuide [Open Source]
there's a name clashing between OL and MG:
an OL layer is an MG Map, what in OL is a Base Layer is NOT what in MG is a
Base Layer.
If the MG Map is made only by Base Layers (MG speaking), you can only toggle
the whole think on and off: in Map Guide 2.0 Developer's Guide at page 31 is
written:
"*Layers within a base layer group are rendered together. Visibility
settings for
individual layers are ignored and the visibility setting for the group is
used
instead.*"
If they are not a BaseLayer, then on server side you must get lay. obj. id:
string strLID1 = mgMap.GetLayers().GetItem("*LAYER NAME 1*").GetObjectId()
string strLIDN = mgMap.GetLayers().GetItem("*LAYER NAME N*").GetObjectId()
[...I think we should not use above code in c#, but make a variable for each
object and despose it... there's no documentation on what must and what must
not be disposed...]
Now suppose that from above code you get the following layer object ids:
strLID1=="id1"
strLIDN=="idN"
and that
"id_s1", ... "id_sk" are the one you want to show
"id_h1,..., "id_hu" are the one you want to hide
Indices
s1,...,sk in J={1,...,n}
h1,...,hu in [{1,...,n} - J]
...ok is not very comprehensible: say we have some layers to show with id
"id_s1", ... "id_sk" and some to hide "id_h1",..., "id_hu".
Now YOU HAVE TO FIND A WAY TO PASS THEM TO CLIENT depending on the server
side language of your chise [note that they will not be valid any more on
MG session expiration!!!]
On client something *like*:
var _mgLayer = null;
var ccc=0;
function someFunc() {
var map = new Openlayers.Map(........);
var baseLayer = (...); *//without a Base Layer (OL speaking) you will not
get OL correctly init*
var url = "*something like
/mapguide/mapagent/mapagent.fcgi?USERNAME=Anonymous&*";
var mgOptions = {
*singleTile: true*,
buffer: 1,
session: "session id taken from server",
mapDefinition: "map def, *better* from server"
[ex.:"Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition"]
*var params = {
showLayers: "id_k1,...,id_sk", //CSV of layer ids to show - taken FROM
SERVER!
hideLayers: "id_h1,...,id_hu" //CSV of layer ids to hide - taken FROM
SERVER!
_mgLayer = new OpenLayers.Layer.MapGuide("custom lay. name", url, params,
mgOptions);
map.addLayer(mgOverlayLayer);
}//end someFunc
function swapHideShow()
if(mgOverlayLayer)
if(ccc++%2==0)
_mgOverlayLayer.params.showLayers = "id_h1,...,id_hu";
_mgOverlayLayer.params.hideLayers = "id_k1,...,id_sk";
else
_mgOverlayLayer.params.showLayers = "id_k1,...,id_sk";
_mgOverlayLayer.params.hideLayers = "id_h1,...,id_hu";
_mgLayer.redraw(true);
Bye,
P.I.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100226/cd423975/attachment.html
