[mapguide-users] Can't create data connexion for multiple raster folder
Kenneth Skovhede ks at geograf.dk
Sun Feb 28 07:57:59 EST 2010
The message is a bug in the GDal provider (or how MapGuide uses it?).
It can safely be ignored, but it means that Maestro will not be able to
preview the layer. Instead, create a map and insert the correct extent
and coordinate system, and then preview the map.
When you add the images, do you simply point to the folder,
or do you build the configuration document?
Regards, Kenneth Skovhede, GEOGRAF A/S
magnoliazz skrev:
> Hello,
> I have a set of 200 rasters that I already reprocessed using the FWTools.
> Now I want to create a data connexion for the folder containing these
> rasters, and it won't work. I choose the files, choose the coordinate
> system, and when I want to save the data source I get this message: "The
> resource had the following warnings: Spatial Context extent appears to be
> invalid (or default) do you want to save it anyway?"
> I should say that these files work fine when added separately, so does
> anyone have an idea what is wrong here?
> thanks
