[mapguide-users] Query Features
sathishpsk9
sathishpsk9 at gmail.com
Tue Jan 5 02:06:40 EST 2010
Hi all, I wish all a vey happy new year...
I have to highlight the parcel which are near to a road..
I have a layer which contains parcels and a road network layer which
contains roadways.
I am capturing the road id through mouse click event and passing that road
id to a page where i perform quering ...........But of no luck..
Here is my code for quering .........
Dim userInfo As New MgUserInformation(sessionId)
Dim siteConnection As New MgSiteConnection()
siteConnection.Open(userInfo)
roadGeo = TextBox1.Text
'create service objects
Dim resourceSrvc As MgResourceService =
TryCast(siteConnection.CreateService(MgServiceType.ResourceService),
MgResourceService)
Dim featureSrvc As MgFeatureService =
TryCast(siteConnection.CreateService(MgServiceType.FeatureService),
MgFeatureService)
Dim map As New MgMap()
map.Open(resourceSrvc, "Map")
Dim nameQuery As New MgFeatureQueryOptions()
Dim val As String = "ROAD_GEO_I" // field of road id there in
property layer
nameQuery.AddFeatureProperty(val)
Dim queryval As String = roadGeo // captured road id captured
through mouse click
Dim totquery As String = (val & "=" & "'") + queryval & "'"
nameQuery.SetFilter(totquery)
Dim layer As MgLayer = map.GetLayers().GetItem("PROPERTY LAYER")
Dim fetresource As New
MgResourceIdentifier("Library://IMCShapeTrade/PropertiesResource.FeatureSource")
Dim featureReader As MgFeatureReader =
featureSrvc.SelectFeatures(fetresource, layer.GetFeatureClassName(),
nameQuery)
Dim featureReader1 As MgFeatureReader =
nameQuery)
Dim i As String = featureReader.GetPropertyName(0)
'featureReader.ReadNext()
Dim selection As New MgSelection(map)
selection.AddFeatures(layer, featureReader1, 0) // error appears
here . "Specified object not found
Dim selectXML As String = selection.ToXml()
selection.Save(resourceSrvc, "Map")
'featureReader.Close()
Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
"select('" & selectXML & "')", True)
Am i doing anything wrong ?
If i can query through both layers by using joins or other features
(intersects , etc) ? if it can done , please give a example code
Please guide in right direction
Thanks & Regards ,
Satish Kumar
View this message in context: http://n2.nabble.com/Query-Features-tp4253901p4253901.html
