[mapguide-users] WMS connection config in MGOS 2.1
iaguilera isidoro.aguilera at aplicad.com
Tue Jan 5 04:12:21 EST 2010
I have found this error in error.log too:
 Error: Failed to stylize layer: WMS1
        An exception occurred in FDO component.
        InvalidDimensionValue:
          Parámetros:
            version=1.1.1
            service=WMS
            REQUEST=GetMap
            EXCEPTIONS=application/vnd.ogc.se_xml
            LAYERS=pnoa
            STYLES=
            CRS=EPSG:23030
            SRS=EPSG:23030
            FORMAT=image/png
            BBOX=-0.393318,39.570482,-0.388907,39.572926
            HEIGHT=554
            WIDTH=790
            TRANSPARENT=TRUE
            BGCOLOR=0xFFFFFF
          Descripción del error:
            La ventana solicitada es inválida
          Servicios disponibles:
iaguilera wrote:
> I'm trying to do a WMS connection to the next WMS service:
> http://www.idee.es/wms/PNOA/PNOA
> and layer: pnoa.
> I want to configure de coordenate system to EPSG:23030, so I included the
> next config.xml file, but the connection doesn't work. Without config.xml
> file the connection works, but I need to specify the coordinate system.
> Where's the problem?:
> <?xml version="1.0" encoding="UTF-8"?>
> <DataStore xmlns:fdo="http://fdo.osgeo.org/schemas"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns="http://fdo.osgeo.org/schemas"
> xsi:schemaLocation="http://fdo.osgeo.org/schemas FdoDocument.xsd">
>   <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
> targetNamespace="http://fdo.osgeo.org/schemas/feature/WMS"
> xmlns:WMS="http://fdo.osgeo.org/schemas/feature/WMS"
> elementFormDefault="qualified" attributeFormDefault="unqualified">
>     <xs:element name="PNOA" type="WMS:PNOA" abstract="false"
> substitutionGroup="gml:_Feature">
>       <xs:key name="PNOAKey">
>         <xs:selector xpath=".//PNOA"/>
>         <xs:field xpath="Id"/>
>       </xs:key>
>     </xs:element>
>     <xs:complexType name="PNOA" abstract="false">
>       <xs:complexContent>
>         <xs:extension base="gml:AbstractFeatureType">
>           <xs:sequence>
>             <xs:element name="Id">
>               <xs:simpleType>
>                 <xs:restriction base="xs:string">
>                   <xs:maxLength value="256"/>
>                 </xs:restriction>
>               </xs:simpleType>
>             </xs:element>
>             <xs:element name="Image" type="fdo:RasterPropertyType"
> fdo:defaultImageXSize="800" fdo:defaultImageYSize="600">
>               <xs:annotation>
>                 <xs:appinfo source="http://fdo.osgeo.org/schemas">
>                   <fdo:DefaultDataModel organization="Row"
> bitsPerPixel="32" tileSizeX="100" tileSizeY="100"/>
>                 </xs:appinfo>
>               </xs:annotation>
>             </xs:element>
>           </xs:sequence>
>         </xs:extension>
>       </xs:complexContent>
>     </xs:complexType>
>   </xs:schema>
>   <SchemaMapping provider="OSGeo.WMS.3.1" name="WMS"
> xmlns="http://fdowms.osgeo.org/schemas">
>     <complexType name="PNOA">
>       <RasterDefinition name="Image">
>         <Format>png</Format>
>         <Transparent>false</Transparent>
>         <BackgroundColor>0xFFFFFF</BackgroundColor>
>         <Time>current</Time>
>         <Elevation>0</Elevation>
>         <SpatialContext>EPSG:23030</SpatialContext>
>         <Layer name="pnoa">
>           <Style/>
>         </Layer>
>       </RasterDefinition>
>     </complexType>
>   </SchemaMapping>
> </DataStore>
View this message in context: http://n2.nabble.com/WMS-connection-config-in-MGOS-2-1-tp4250883p4254237.html
