[mapguide-users] Does MGOS use worldfiles?
Hardt
preinhart at environcorp.com
Tue Jan 12 09:25:48 EST 2010
I cannot see it.
I tried to change the initial view values, but when I save Maestro reset
them to -10000000 and 10000000
I am completely lost.
Andrew DeMerchant wrote:
> But is your image in there somewhere (just very very zoomed out,
> perhaps)? If you set your inital view to some coords that actually land
> on your image, does it work?
> On 1/12/2010 10:08 AM, Hardt wrote:
>> No, when I add the layer to a map, then set the initial view of the map
>> using
>> the ad hoc button, I get -10000000 and 10000000 in the X Y fields.
>> And when I view the map I have a white map.
>>> I don't think that a world file can have the coord system info in it, so
>>> having the coord system show up as local_cs isn't unusual. when you
>>> preview the layer, is it not in the right place?
>>> On 1/12/2010 10:02 AM, Hardt wrote:
>>>> It seems that they don't for me.
>>>> When I create a dataconnection with GDAL provider, I add my .jpg and
>>>> .jgw
>>>> files, but then the config file is empty, and the coordinate system is
>>>> LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]
>>>>> World files work fine in MGOS - at least they have and do for me...
>>>>> Andrew
>>>>> On 12/8/2009 11:38 AM, Hardt wrote:
>>>>>> Hi,
>>>>>> I am still fighting with MGOS 2.1 to have nice rasters.
>>>>>> I wondered if MGOS uses worldfiles or if they are useless?
>>>>>> Thanks,
>>>>>> Hardt
>>>>> *Andrew DeMerchant*
>>>>> *Computer Technologist*
>>>>> ph.1-877-2GEMTEC x.163
>>>>> fax 506-453-9470
>>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>>> /191 Doak Road
>>>>> Fredericton, NB, Canada
>>>>> E3C 2E6
>>>>> This e-mail message (including attachments, if any) is confidential
>>>>> and
>>>>> may be privileged. Any unauthorized distribution or disclosure is
>>>>> prohibited. Disclosure to anyone other than the intended recipient
>>>>> does
>>>>> not constitute waiver of privilege. If you have received this e-mail
>>>>> in
>>>>> error, please notify us and delete it and any attachments from your
>>>>> computer system and records.
>>>>> Ce courriel (y compris les pièces jointes) est confidentiel et peut
>>>>> être
>>>>> privilégié. La distribution ou la divulgation non autorisée de ce
>>>>> courriel est interdite. Sa divulgation à toute personne autre que son
>>>>> destinataire ne constitue pas une renonciation de privilège. Si vous
>>>>> avez
>>>>> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce
>>>>> courriel,
>>>>> ainsi que les pièces jointes, de votre système informatique et de vos
>>>>> dossiers.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
>>> This e-mail message (including attachments, if any) is confidential and
>>> prohibited. Disclosure to anyone other than the intended recipient does
>>> not constitute waiver of privilege. If you have received this e-mail in
>>> être
>>> avez
>>> courriel,
>>> dossiers.
> *Andrew DeMerchant*
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> E3C 2E6
> Ce courriel (y compris les pièces jointes) est confidentiel et peut être
> destinataire ne constitue pas une renonciation de privilège. Si vous avez
> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel,
> dossiers.
http://n2.nabble.com/file/n4291860/aix.jpg aix.jpg
http://n2.nabble.com/file/n4291860/aix.jpgw aix.jpgw
View this message in context: http://n2.nabble.com/Does-MGOS-use-worldfiles-tp4133221p4291860.html
