[mapguide-users] Does MGOS use worldfiles?
Hardt
preinhart at environcorp.com
Tue Jan 12 09:58:50 EST 2010
I think that I found something: If I use the Specific editor during
dataconnection creation, I get an empty config file, and an empty layer or
map when viewing in the browser.
If I use the Custom editor, the config file is not empty, and I get an image
when I view it in the browser... (even if that doesn't solve my jgw issue,
that is much better).
That's for the blank map.
If I upload the jpg and the jgw file in the custom editor, when I test the
connection, I get an error message:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Failed to de-serialize the schema mappings from the configuration.
This error doesn't appear if I take out the jgw file.
Eventually, with or without the jgw file, I get a default config file with
default bounding box
<gml:boundingBox>
<gml:pos>-10000000 -10000000</gml:pos>
<gml:pos>10000000 10000000</gml:pos>
</gml:boundingBox>
and a default coordinate system
<fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
Andrew DeMerchant wrote:
> Add it to a map and set the extents to something real - then look at the
> map and see if you see the image.
> On 1/12/2010 10:25 AM, Hardt wrote:
>> I cannot see it.
>> I tried to change the initial view values, but when I save Maestro reset
>> them to -10000000 and 10000000
>> I am completely lost.
>>> But is your image in there somewhere (just very very zoomed out,
>>> perhaps)? If you set your inital view to some coords that actually land
>>> on your image, does it work?
>>> On 1/12/2010 10:08 AM, Hardt wrote:
>>>> No, when I add the layer to a map, then set the initial view of the map
>>>> using
>>>> the ad hoc button, I get -10000000 and 10000000 in the X Y fields.
>>>> And when I view the map I have a white map.
>>>>> I don't think that a world file can have the coord system info in it,
>>>>> so
>>>>> having the coord system show up as local_cs isn't unusual. when you
>>>>> preview the layer, is it not in the right place?
>>>>> On 1/12/2010 10:02 AM, Hardt wrote:
>>>>>> It seems that they don't for me.
>>>>>> When I create a dataconnection with GDAL provider, I add my .jpg and
>>>>>> .jgw
>>>>>> files, but then the config file is empty, and the coordinate system
>>>>>> is
>>>>>>> World files work fine in MGOS - at least they have and do for me...
>>>>>>> Andrew
>>>>>>> On 12/8/2009 11:38 AM, Hardt wrote:
>>>>>>>> Hi,
>>>>>>>> I am still fighting with MGOS 2.1 to have nice rasters.
>>>>>>>> I wondered if MGOS uses worldfiles or if they are useless?
>>>>>>>> Thanks,
>>>>>>>> Hardt
>>>>>>> *Andrew DeMerchant*
>>>>>>> *Computer Technologist*
>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>> fax 506-453-9470
>>>>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>>>>> /191 Doak Road
>>>>>>> Fredericton, NB, Canada
>>>>>>> E3C 2E6
>>>>>>> This e-mail message (including attachments, if any) is confidential
>>>>>>> and
>>>>>>> may be privileged. Any unauthorized distribution or disclosure is
>>>>>>> prohibited. Disclosure to anyone other than the intended recipient
>>>>>>> does
>>>>>>> not constitute waiver of privilege. If you have received this
>>>>>>> e-mail
>>>>>>> in
>>>>>>> error, please notify us and delete it and any attachments from your
>>>>>>> computer system and records.
>>>>>>> Ce courriel (y compris les pièces jointes) est confidentiel et peut
>>>>>>> être
>>>>>>> privilégié. La distribution ou la divulgation non autorisée de ce
>>>>>>> courriel est interdite. Sa divulgation à toute personne autre que
>>>>>>> son
>>>>>>> destinataire ne constitue pas une renonciation de privilège. Si
>>>>>>> vous
>>>>>>> avez
>>>>>>> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce
>>>>>>> courriel,
>>>>>>> ainsi que les pièces jointes, de votre système informatique et de
>>>>>>> vos
>>>>>>> dossiers.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> *Andrew DeMerchant*
>>>>> fax 506-453-9470
>>>>> /191 Doak Road
>>>>> E3C 2E6
>>>>> and
>>>>> does
>>>>> not constitute waiver of privilege. If you have received this e-mail
>>>>> in
>>>>> être
>>>>> courriel est interdite. Sa divulgation à toute personne autre que son
>>>>> destinataire ne constitue pas une renonciation de privilège. Si vous
>>>>> avez
>>>>> courriel,
>>>>> ainsi que les pièces jointes, de votre système informatique et de vos
>>>>> dossiers.
>>> *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
>>> This e-mail message (including attachments, if any) is confidential and
>>> prohibited. Disclosure to anyone other than the intended recipient does
>>> not constitute waiver of privilege. If you have received this e-mail in
>>> être
>>> avez
>>> courriel,
>>> dossiers.
>> http://n2.nabble.com/file/n4291860/aix.jpg aix.jpg
>> http://n2.nabble.com/file/n4291860/aix.jpgw aix.jpgw
> *Andrew DeMerchant*
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> E3C 2E6
> Ce courriel (y compris les pièces jointes) est confidentiel et peut être
> destinataire ne constitue pas une renonciation de privilège. Si vous avez
> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel,
> dossiers.
View this message in context: http://n2.nabble.com/Does-MGOS-use-worldfiles-tp4133221p4292065.html
