[mapguide-users] Access a Mapguide tile cache over multiple
hostnames through Openlayers
GNEMMI Ludovic
LGNEMMI at rgd73-74.fr
Wed Jan 13 04:14:45 EST 2010
Hi Zac,
I haven't any pubic example but you can observe this behavior with your wonderfull exploreaustralia map.
Unfortunately i think the patch is limited to Mapguide viewer.
Ludovic
-----Message d'origine-----
Objet : Re: [mapguide-users] Access a Mapguide tile cache over multiple hostnames through Openlayers
is that possibility or observed behavior?
there was a patch posted by bruno which addresses that,
i think off the top of my head
z
2010/1/13 GNEMMI Ludovic <LGNEMMI at rgd73-74.fr>:
> Hi list,
> I would like to use multiple hostnames to load faster Mapguide tiles exposed
> directly via a webserver but it seems that a given tile is not loaded each
> time
> from the same hostname. There is the potential for the tile being cached 4
> times when 4 hostnames are defined.
> I thought Openlayers was able to handle this possibility. Am i doing
> something wrong or this option doesn't work with mapguide http Layers?
> var urlArray =[
> "http://server1/MgTiles/","http://server2/MgTiles/","http://server3/MgTiles/","http://server3/MgTiles/"];
> var httpLayer = new OpenLayers.Layer.MapGuide( "Orthophoto", urlArray,
> params, options );
> Thanks for your help
> Ludovic
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
