[mapguide-users] Measure Widget Problem
LLEUNDD
nuell at nicholsenvironmental.com
Wed Jan 13 12:01:58 EST 2010
I am using a different projection than the person above. I have all my
layers projected to UTM83-11 and can measure correctly in other GIS programs
(i.e., ArcGIS, MapInfo), however when the same layers are brought into
Mapguide studio and placed into maps/layouts, the measure widget displays an
incorrect measurement.
I can even take off the projections and display then using an arbitrary X/Y
coordinate system with the same results.
Anyone else having similar issues?
Cheers!
Homan, Thomas wrote:
> Any chance you're in the wrong coordinate system? Specifically meters
> and feet. I've not seen many datasets where UTM83 was converted from its
> native metric definition to feet like you have in the UTM83-12F(eet)
> Just an observation
> Tom
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of LLEUNDD
> Sent: Tuesday, January 12, 2010 12:18 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Measure Widget Problem
> Did you find an answer for this? I am having the same issues with MG
> 2.1
> Greg Neff wrote:
>> I am having problems with the measure widget in Mapguide 2.1: The
>> measurements give are really large, on the order of 60000 times the
> actual
>> measurement. The coordinate system for the map is UTM83-12F. I am
> new to
>> Mapguide and don't know enough to track down my problem. Hopefully
>> someone
>> here can help.
>> Thanks,
>> Gregory B. Neff
>> District Engineer
>> Cottonwood Improvement District
>> 8620 Highland Dr.
>> Sandy, Utah 84093
>> (801) 943-7671
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Measure-Widget-Problem-tp4225407p4293737.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Measure-Widget-Problem-tp4225407p4354400.html
