[mapguide-users] MapGuide with ASP.Net
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jan 15 03:08:38 EST 2010
There is no need to also install PHP.
MapGuide has PHP installed anyway, you do not need the PHP viewer.
It makes things easier if you install MGOS and VS on the same machine,
but it is not required.
If you use seperate machines, you have to copy over a few files from
MGOS (the bin folder from the viewer and the webconfig.ini).
You also need to ensure that the appropriate ports are open between the
two machines (ports are listed in webconfig.ini).
Regards, Kenneth Skovhede, GEOGRAF A/S
On 13-01-2010 10:08, kandiyateesh wrote:
> installed on a different machine (from the machine where
> MapGuide Open Source and Maestro have been install
