[mapguide-users] Searching for a sample C# application for searching multiple fields of a feature class
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jan 15 03:41:15 EST 2010
I don't have a comple sample that fits your description,
but some bits and pieces (chunks if you prefer).
I personally use MaestroAPI (for obvious reasons):
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
Using the MaestroAPI samples as a base, I have put together this quick
untested sample of the server code:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/QueryFeatureSource
Another way to do it is show here:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/FormExpression.cs#L732
The interesting line is 751:
using (FeatureSetReader rd =
m_connection.QueryFeatureSource(m_featureSource,
m_schema.FullnameDecoded, filter, new string[] { ColumnName.Text }))
     while (rd.Read())
    { } //Read data here
If you do not want to use MaestroAPI, you can look at the MaestroAPI
source code to figure out
how to use the MgFeatureService object to query features.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 13-01-2010 10:46, Dejan Gregor wrote:
> Hi,
> I am new to development in MapGuide and C# programming. I would like to
> implement a sample C# application for searching multiple fields of a vector
> FDO feature class (e.g. parcel numbers and other description). I am using
> MGOS 2.1.
> I would need a complete sample code (not just chunks) that I could directly
> implement, but maybe searching on the wrong place. I have a simple AJAX
> Viewer, not Fusion.
> Does anyone know a place to search or submit a stable search engine sample?
> Thanks!
> Dejan
> Dejan Gregor, MSc
> GISc Researcher and Consultant
> http://www.linkedin.com/in/dgregor
