[mapguide-users] Application compatibility b/w MGE2009 and MGOS 2.0.2
Dejan Gregor dejan.gregor at GMAIL.COM
Fri Jan 15 04:48:37 EST 2010
I have tried to run it, but I got following error :
Execute of corflags.exe  failed
Execute of ildasm.exe /? failed
An unexpected processing error did occur: System.NullReferenceException:
Object
reference not set to an instance of an object.
   at Signer.Executor.GetInvalidCommands()
   at Signer.Program.Execute()
   at Signer.Program.Main(String[] args)
I will wait your information. Thanks!
Dejan
On Fri, Jan 15, 2010 at 10:13, Kenneth Skovhede, GEOGRAF A/S [via OSGeo.org]
<ml-node+4397661-1944273353 at n2.nabble.com<ml-node%2B4397661-1944273353 at n2.nabble.com>
> wrote:
> You only need an updated MapGuideDotNetApi if you are using the
> LocalNativeConnection.
> I will upload the updated signed dll files later today (appx 20:00 GMT)
> If you cannot wait, the command to sign MapGuideDotNetApi is:
> signer.exe -k maestroapi.key -outdir .\out -a MapGuideDotNetApi.dll
> Signer.exe and the key is in SVN:
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Signer/Signer.exe?format=raw
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/maestroapi.key?format=raw
> The bindingRedirect setup is as follows:
> <?xml version="1.0"?>
> <configuration>
> <runtime>
> <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
> <dependentAssembly>
> <assemblyIdentity name="MapGuideDotNetApi"
> publicKeyToken="f526c48929fda856" />
>                  NOTE: href MUST be absolute, alternative is to just rename
>                  the desired version of the file and replace
>                  If you choose the rename option, remove the <codeBase>
> tags below,
>                  but keep the <bindingRedirect>
> <codeBase version="1.2.0.4103" href="MapGuideDotNetApi-1.2.dll"/>
> <codeBase version="2.0.0.2308" href="MapGuideDotNetApi-2.0.dll"/>
> <codeBase version="1.0.0.1" href="MapGuideDotNetApi-2.1.dll"/>
> <!-- Activate MGOS 1.2, MGEP 2008 -->
> <!-- <bindingRedirect oldVersion="2.0.0.2308" newVersion="1.2.0.4103" />
> <!-- Activate MGOS 2.0, MGEP 2009 , *default* -->
> <!-- <bindingRedirect oldVersion="2.0.0.2308" newVersion="2.0.0.2308" />
> <!-- Activate MGOS 2.1, MGEP 2010 -->
> <bindingRedirect oldVersion="2.0.0.2308" newVersion="1.0.0.1" />
> </dependentAssembly>
> </assemblyBinding>
> </runtime>
> </configuration>
> Regards, Kenneth Skovhede, GEOGRAF A/S
> On 15-01-2010 09:41, Dejan Gregor wrote:
> > Kenneth,
> > I am using the verion 2.1.0.3505 for MapGuideDotNetApi. Where should I
> set
> > the version value (newVersion or oldVersion) and is the publicKeyToken
> still
> > 'f526c48929fda856'?
> > I am using MGE 2010.
> > Dejan
> > Kenneth Skovhede, GEOGRAF A/S wrote:
> >> The "Invalid Stream Header" is a sort-of catch-all exception that
> happens
> >> when the MapGuide service tries to de-serialize an object, and finds
> >> something it does not expect.
> >> The usual cause of this is the other (unmanaged) binaries.
> >> The MapGuideDotNet.dll file is a thin wrapper that just calls the
> >> unmanaged dll's.
> >> So you can bind .Net to either version of the managed dll, but you MUST
> >> have the correct
> >> unmanaged dll's in the bin folder.
> >> Alternatively, you can fix the binding through the Web.config file:
> >> <configuration>
> >>    <runtime>
> >>        <dependentAssembly>
> >>      </assemblyBinding>
> >>    </runtime>
> >> </configuration>
> >> Replace the publicKeyToken and version as you please.
> >> There was a slight change with MgDisposable/MgGuardedDisposable some
> >> time ago.
> >> If you run into that, you have to use the re-bind option described
> above.
> >> MacNair skrev:
> >>> We have a Mapguide application developed using MGE 2009’s library.
>  This
> >>> application does most of its work by calling methods from another DLL
> >>> called
> >>> “MGEUtils.DLL”. This DLL references “MapGuideDotNet.DLL”.
> >>> The application works fine on the development machine where MGE is
> >>> installed. But on the deployment machine where MapGuide Open Source
> (MGOS
> >>> 2.0.2.3011) is installed we are getting a few errors.
> >>> Should we recompile the class library “MGEUtils” referencing MGOS’s
> >>> MapGuideDotNet.DLL?
> >>> The calls made to the methods in MGEUtils to initialize the application
> >>> are
> >>> throwing a few errors as given under. Note: The function definitions
> for
> >>> these methods are given in Appendix below:
> >>> // Initialize the webtier
> >>> string sErrMsg = "";
> >>> mgeUtils.InitializeWebTier(configPath, sErrMsg);
> >>> // Validate the user login and create a session
> >>> mgeUtils.InitialiseSession("Anonymous", "", ref sessionId, ref
> sErrMsg);
> >>> Note:  The function definitions for the above calls within MGEUtils are
> >>> given at the end of this document.
> >>> Errors encounterd are…
> >>> CASE I: Placing MGE’s MapGuideDotNet.dll  along with “MGEUtils.DLL”  in
> >>> the
> >>> application’s bin directory.
> >>> Error @ LINE: mgeUtils.InitialiseSession("Anonymous", "", ref
> sessionId,
> >>> ref
> >>> sErrMsg);
> >>> Error details: OSGeo.MapGuide.MgInvalidStreamHeaderException: Invalid
> >>> stream
> >>> header exception
> >>> CASE II: Placing MGOS ’s MapGuideDotNet.dll  along with “MGEUtils.DLL”
> >>> in
> >>> the application’s bin directory.
> >>> Error @ LINE: mgeUtils.InitializeWebTier(configPath, sErrMsg);
> >>> Error details: Could not load file or assembly 'MapGuideDotNetApi,
> >>> Version=2.0.0.3202, Culture=neutral, PublicKeyToken=6416a18f8953383b'
> or
> >>> one
> >>> of its dependencies. The located assembly's manifest definition does
> not
> >>> match the assembly reference. (Exception from HRESULT: 0x80131040)
> >>> Any help on this? Sorry for the lengthy mail. Thanks!
> >>> Function defintions
> >>> public bool InitializeWebTier(string configPath, string csErrMsg)
> >>>     try
> >>>       // Check if the webConfig file exists
> >>>       if (!File.Exists(configPath)) { return false; }
> >>>       MapGuideApi.MgInitializeWebTier(configPath);
> >>> return true;
> >>>      catch (MgConnectionFailedException mge)
> >>> csErrMsg = mge.GetMessage();
> >>> return false;
> >>> public bool InitialiseSession(string userName, string userPwd, ref
> string
> >>> sessionId, ref string csErrMsg)
> >>>    try
> >>>     // Validate user login
> >>>     MgUserInformation userInfo = new MgUserInformation(userName,
> userPwd);
> >>>     MgSite site = new MgSite();
> >>>     site.Open(userInfo);
> >>>     // Create a session
> >>>     sessionId = site.CreateSession();
> >>>     return false;
> >>>    return true;
> >> _______________________________________________
> >> mapguide-users mailing list
> >> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4397661&i=0>
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > Dejan Gregor, MSc
> > GISc Researcher and Consultant
> > http://www.linkedin.com/in/dgregor
> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4397661&i=1>
>  View message @
> http://n2.nabble.com/Application-compatibility-b-w-MGE2009-and-MGOS-2-0-2-tp1819071p4397661.html
> To unsubscribe from Re: Application compatibility b/w MGE2009 and MGOS
> 2.0.2, click here< (link removed) >.
Dejan Gregor, MSc
View this message in context: http://n2.nabble.com/Application-compatibility-b-w-MGE2009-and-MGOS-2-0-2-tp1819071p4397794.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100115/c2008b12/attachment.html
