[mapguide-users] get started using the Visual studio 2005
Jackie Ng
jumpinjackie at gmail.com
Mon Jan 18 07:15:17 EST 2010
Also make sure your web application is using ASP.net 2.0 in IIS manager.
- Jackie
fayeZOEL wrote:
> Hi all,
> I am new to mapguide2010. I just want to confirm is it my steps are
> correct when get started using the asp.net .
> 1. Open IIS create a virtual directory under the Default website , name it
> whatever i like (faye_testing) and browse the directory under the
> C:\Program Files\Autodesk\MapGuideEnterprise2010\WebServerExtensions\www.
> 2. Open the Visual Studio 2005, select "open website". Click the "Local
> iis" from the left pane. then browse to the directory that i created just
> now.
> 3. add a bin and past all dlls (C:\Program
> Files\Autodesk\MapGuideEnterprise2010\WebServerExtensions\www\Bin) inside
> Bin dlls
> 4. start do some coding .. and testing..
> 5. click F(5) to start debug ...
> do i miss up any steps ? Hope all can give me some advices or comments!
> Thanks
> -faye
View this message in context: http://n2.nabble.com/get-started-using-the-Visual-studio-2005-tp4412689p4413318.html
