[mapguide-users] GeoREST 1.0 Released!
Haris Kurtagic haris at sl-king.com
Mon Jan 18 16:41:08 EST 2010
I will jump a bit before Jason answers it :)
Yes, one of advantages of GeoREST is that you don't need additional server
side code to allow MapGuide to talk with database.
In our implementations we use just HTML forms (in some cases with javascript
but plain html form would work too) to edit data. By submitting HTML form to
GeoREST , data will be updated either trough MapGuide or trough FDO
depending of particular layer configuration.
Another use of HTML forms is to create query/filter request to search over
data.
Also to generate reports (HTML) we use only html like text templates, no
server side code needed to create html's from MapGuide/FDO data.
Haris
On Mon, Jan 18, 2010 at 4:55 PM, BradM <brad.mason at dfo-mpo.gc.ca> wrote:
> Jason can we use GeoREST to create data entry forms and reports that allow
> Mapguide to talk to databases?    Does GeoREST replace the need for using
> PHP forms and coldfusion forms?
> thanks
> Jason Birch wrote:
> > We are pleased to announce the first major release of GeoREST, a new Open
> > Source framework for publishing and interacting with geospatial data as
> > web
> > resources.  GeoREST leverages, among other Open Source libraries, both
> > MapGuide and FDO as data sources.
> > With GeoREST 1.0 you can enable search engines to crawl your geospatial
> > data, dynamically publish to KML, GeoRSS or any other text based format,
> > use
> > web forms to search and update your data, and more. All of this
> > functionality is available entirely through configuration... no
> > programming
> > required!
> > Please visit the GeoREST project website for more information on GeoREST
> > and
> > the benefits it can bring to your geospatial publishing strategy.
> > http://www.georest.org/
> > For a quick look, here are two sites that have been using GeoREST in a
> > production environment for over nine months, with great improvements in
> > the
> > accessibility of their data:
> > http://maps.nanaimo.ca/data/
> > http://share.vo-ka.si/iskanje/ (Slovenian)
> > And an example of using OpenLayers to edit a GeoREST vector layer
> overlaid
> > on a MapGuide image service:
> > http://www.sl-king.com/<
> http://www.sl-king.com/georestsamples/example1/rview.html>
> > georestsamples
> > <http://www.sl-king.com/georestsamples/example1/rview.html>/<
> > example1
> > rview
> > <http://www.sl-king.com/georestsamples/example1/rview.html>.ht<
> > ml <http://www.sl-king.com/georestsamples/example1/rview.html>
> > GeoREST is an independent Open Source project licensed under LGPL, though
> > our hope is that it will be integrated with the MapGuide project in the
> > future. It is available for installation on the Windows platform using
> > either the GeoREST built-in webserver or IIS.
> > We would love to hear what you think about GeoREST. Please join the
> > project's mailing list today and help us shape its future.
> > Jason Birch and Haris Kurtagic
> > P.S. Any help porting this project to run on Linux would be greatly
> > appreciated!
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/GeoREST-1-0-Released-tp4212935p4414314.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100118/b8a42fb3/attachment.html
