[mapguide-users] Re: Start with a map coordinates passed by
parameters in the URL
Jackie Ng
jumpinjackie at gmail.com
Wed Jan 20 05:59:09 EST 2010
What you could do is on startup, to read the content of your WebLayout,
modify it's initial view section to contain your coordinates, write the
modified content to your session repository and point your AJAX viewer to
load the session-based WebLayout.
There's a PHP example here:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/PHP/InitialMapView
Note that with this approach, every time you reset your view in the AJAX
viewer, it will reset to your custom initial position and scale.
- Jackie
View this message in context: http://n2.nabble.com/Start-with-a-map-coordinates-passed-by-parameters-in-the-URL-tp4425806p4425859.html
