[mapguide-users] RE: IIS Configuration of Mapguide OS - testing
web server extensions fails
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jan 21 03:34:18 EST 2010
404 errors either means that:
you have not mapped the file correctly (eg. it does not exist),
or that the extension is not registered (eg. no handler for .php files),
or that the extension is not allowed to run (eg. the executable path is
not listed as allowed in the extensions section)
Unfortunately it is not possible to determine which of the three cases
you are experiencing,
without a complete listing of mappings, folders, permissions, etc..
Regards, Kenneth Skovhede, GEOGRAF A/S
On 20-01-2010 11:31, padmini godavarthi wrote:
> Hi,
> iam using Windows 2003 Server and Mapgide Opensource 2.1..........
> I also have the save Problem................
> Can u plz tell me the solution ?
> While running Web server Extensions i got an error that
> Page can not be found....................................
> how to get my aspnet_isapi.dll ????????????????
> Noe:-There is No Visual studio installed on my system...... Only .Net Frame
> work 2.0 is there in my system..............
