[mapguide-users] Start the map with coordinates specified in the URL
Rubén Casal Prieto terri2213 at msn.com
Fri Jan 22 11:58:58 EST 2010
The exact error is as follows:
An unclassified exception occurred.
An unclassified exception occurred. Exception occurred in method
MgWebLayout.ParseWebLayoutDefinition at line 293 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\web\src\webapp\WebLayout.cpp
She copied it wrong ...
The error occurs after this.
...src ="../ mapviewernet / ajaxviewer.aspx? SESSION = <% = sessionId%> &
> WEBLAYOUT = <% = webLayout%> " /...
That is not formed XML must be valid to form the layout of session. I think
... You know where they can be? Thanks for your reply and best regards!
View this message in context: http://n2.nabble.com/Start-the-map-with-coordinates-specified-in-the-URL-tp4434674p4441236.html
