[mapguide-users] Guide Me in MGOS 2.1
padmini godavarthi
godavarthi.padmini at gmail.com
Fri Jan 29 05:13:45 EST 2010
Hi
iam using MGOS 2.1 with Mapguide Maestro 1.0.9 on iis 6.0
Microsoft visual studio 2008 Expression edition on windows xp service pack2
by clicking on show in browser in maestro the map appears fine on Browser
i found the error that while developing a sample application,
MapGuideDotNetApi.dll of assembly version 2.0.0.2308 is appeared in my
application so, i deleted it on my application and placed
MapGuideDotNetApi.dll of assembly version 1.0.0.1 in my application as told
by kenneth in
http://n2.nabble.com/MapGuide-2-1-Ok-in-Studio-error-Message-in-IE-Impossible-to-Get-Entry-Point-td3080482.html#a3082009
but after running the application the MapGuideDotNetApi.dll of assembly
version 2.0.0.2308 is again appears in my application
my code is as follows
Imports OSGeo.MapGuide
Imports OSGeo.MapGuide.MaestroAPI
Imports System.Web.UI.HtmlControls
Imports System.Collections.Specialized.NameValueCollection
(Main.aspx.vb)
Partial Class _Default
Inherits System.Web.UI.Page
Public sessionId As String
Public webLayout As String
Dim resrce As ResourceIdentifier
Public layout As WebLayout
Protected Sub Page_Load(ByVal sender As Object, ByVal e As
System.EventArgs) Handles Me.Load
Dim realPath As String =
Request.ServerVariables("APPL_PHYSICAL_PATH")
Dim configPath As String = realPath + "webconfig.ini"
MapGuideApi.MgInitializeWebTier(configPath)
Dim userinfo As MgUserInformation = New
MgUserInformation("Administrator", "admin")
'Dim mgsiteconn As MgSiteConnection = New MgSiteConnection()
Dim site As MgSite = New MgSite()
site.Open(userinfo)
sessionId = site.CreateSession()
Dim host As Uri = New
Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
Dim conn As HttpServerConnection = New HttpServerConnection(host,
"Administrator", "admin", "en", True)
layout = conn.GetWebLayout("Library://sample/Layout.WebLayout")
resrce = New ResourceIdentifier("sample", ResourceTypes.WebLayout,
sessionId)
conn.SaveResourceAs(layout, resrce)
HttpContext.Current.Session("sid") = sessionId
HttpContext.Current.Session("layout") = resrce
End Sub
End Class
and the (main.aspx)
<body>
<form id="form1" runat="server">
<div>
<iframe id="titleframe" runat="server" frameborder="1" visible="true"
src="title.html">
</iframe>
</div>
<iframe id="I1"
src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=layout%>"
</iframe>
</form>
</body>
can u plz tell me the solution
and my doubts are
1) is mgos 2.1 supports the environment of MS VS 2008 Expression Edition?
(because in iis i configured the mapguide to .net framework 2.0 only)
Regards,
Padmini G.
View this message in context: http://n2.nabble.com/Guide-Me-in-MGOS-2-1-tp4479159p4479159.html
