[mapguide-users] Connecting to an Excel Database
Zac Spitzer
zac.spitzer at gmail.com
Fri Jul 2 23:14:33 EDT 2010
try via access with a linked linked excel table ?
On 3 July 2010 03:36, DGK <kerrcad at gmail.com> wrote:
> The subject itself should describe my experience level... (extreme newbie)
> The goal is simply to attach a point file and place symbols on a map. I
> have been through the "Autodesk Official Traning Guide" for Mapguide 2010
> and searched "Excel" under the users group to no avail. But for this simple
> task still I'm lost...
> The point file is an Excel spreadsheet with these columns:
> ID SITE LAT LON
> 1 NY-ROC001 43.1851967 -77.641065
> 2...149
> Tried a couple of Methods to Connect see below (no user credentials required
> in any case).
> The problem is the Excel file? - Used Excel 2003, except for DSN connection
> - then saved as Excel 5.0
> Please advise - I've become the definition of insanity - doing the same
> thing over and over and expecting a different result...
> Dan
> What follows are the specific steps taken for everything I can think of...
> Attempt 1 Failure:
> Type of Connection - OSGeo FDO Provide for ODBC
> "Connect to a file and upload to the MapGuide Library"
> New - Select file SyrRocLocations01.xls (on local machine, not a network
> drive)
> Type of database - Microsoft Excel Driver (*.xls)
> Connection String - Driver={Microsoft Excel Driver
> (*.xls)};DriverId=790;Dbq=%MG_DATA_FILE_PATH%SyrRocLocations01.xls;DefaultDir=%MG_DATA_FILE_PATH%;
> Test Connection - Successful connection
> Under Define geometry properties... Press "Show Tables" - nothing appears
> Press Refresh - Failed to retrieve message for "MgIndexOutOfRangeException".
> The value is invalid because it is too large.
> Attempt 2 Failure:
> Type of Connection - OSGeo FDO Provider for ODBC
> "Connect to an External File"
> File to connect to - %MG_DATA_PATH_ALIAS[DATA_FILES]%/SyrRocLocations01.xls
> (alias is set up properly)
> Type of Database - Microsoft Excel Driver (*.xls)
> (*.xls)};DriverId=790;Dbq=%MG_DATA_PATH_ALIAS[DATA_FILES]%/SyrRocLocations01.xls;DefaultDir=%MG_DATA_PATH_ALIAS[DATA_FILES]%;
> Test Connection - An exception occurred in FDO component. RDBMS: No current
> open database.
> Attempt 3 Failure:
> Type of Connection -OSGeo FDO Provider for ODBC
> "Connect via a DataDource Name (DSN) set up on the server"
> Create DSN on server, select connection name (made sure to save file as
> Excel 5.0 and use like dsn driver)
> Test Connection - Successful Connection
> Refresh - Failed to retrieve message for "MgIndexOutOfRangeException". The
> Tried to Create a layer from each of the data sources:
> Create Layer fron Excel Upload (1 above) <OR>
> Create Layer From External file (2 above) <OR>
> Create Layer From DSN connection (3 above) <=>
> In all cases:
> "The Feature Class is Invalid..."
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Connecting-to-an-Excel-Database-tp5248617p5248617.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
