[mapguide-users] Fusion: calling custom search widget
Warren Medernach wmedernach at rand.com
Mon Jul 5 13:27:04 EDT 2010
Hello all,
I have a search defined in a Fusion app that works fine, and this search is defined to execute in a specified frame.  I can control the opening and closing of this frame via javascript, but what I want to do is script this so I can call to open the frame and then load the Search command.
I was thinking of wrapping this in an InvokeScript call, so I'm looking for help with the syntax to 'call/activate/initialize' the custom search widget.
I've seen other samples using something like:
window.top.Fusion.getWidgetById('Map').drawMap()  to refresh a map
My search ID is 'SearchAddress' so I've tried:
window.top.Fusion.getWidgetById('SearchAddress').activate;
But that doesn't seem to work.
Warren M
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100705/20fe6d03/attachment.html
