[mapguide-users] Re: Get Informtaion from Multiple Layers
jgormont
jgormont at jeffersoncountywv.org
Tue Jul 6 16:04:42 EDT 2010
Thank you for responding. I reviewed the two sets of code you sent and, while
they would probably work, they aren't quite what I'm looking for. I've
actually created a Search for the address layer already, so I really just
need to figure out the Query side of it. However, the Query search from the
sample looked too complicated for the map I wish to create. The end user of
the map is most likely to be a general citizen, so they would probably take
one look at the Query and decide that it wasn't worth trying to figure it
out.
What I am hoping to do instead is to allow them to search the Address point
layer for their address, and either have that selection retrieve all the
fields I choose from the other layers for that point as well as the address
(prefered) or at least have only one other search where they can select a
point or rectangle and it will retrieve all the info for that spot.
Also, I would prefer being able to set up what fields are retrieved rather
than the user. It's just easier that way.
Any suggestions?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Get-Informtaion-from-Multiple-Layers-tp5243608p5262219.html
