[mapguide-users] How to???
Jason Birch jason at jasonbirch.com
Tue Jul 6 21:52:15 EDT 2010
There are a LOT of changes in that ticket, and they may be depending on
changes that were made in other tickets, etc.  Trying to apply patches to
released code (rather than something you build from a particular SVN branch)
is hard to get right, especially for a code base as large as MapGuide.
Are you in a position where you could try the 2.2 beta stream?
http://trac.osgeo.org/mapguide/wiki/Release/2.2Beta/Notes
If not, you may find someone able to walk you through the errors you are
seeing (if you post them and the circumstances where they occur) but the
chances of that are not great, and the probability of successful outcome are
low (in my opinion).
Jason
On 6 July 2010 11:13, swap wrote:
> This could be a basic matter.
> I have installed mgos 2.1.0 on linux server, it comes to crash often by web
> tier. After googling, read in this and make a lot of questions, I found
> that
> it is solved on track ticket #1110.
> I have downloaded the files fixed and repleaced the original on install
> source, when tried to reinstall them shows many errors, like instance not
> defined or variable not found.
> ¿You can tell me how to fix intallation using the track fixed files? , this
> is now my headache.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100706/45b5ca43/attachment.html
