[mapguide-users] Highlight features on mapguide mapframe with
alphanumeric query (no spatial)
kmtnck
alessandro.modica at gmail.com
Mon Jul 12 07:32:21 EDT 2010
I all guys.
I have a trouble problem during my envelope about a web application gis that
use mapguide as application server repository to retrieve map designed in
autocad.
Actually I able to highlights some features in a map, executing in sequence
a spatial query with a request operation denominate QUERYMAPFEATURES for
singular feature. I able to regenerate a final xml of FeatureInformation xml
type
AQAAAA==
AgAAAA==
AwAAAA==
BAAAAA==
BQAAAA==
BgAAAA==
BwAAAA==
CAAAAA==
CQAAAA==
CgAAAA==
CwAAAA==
DAAAAA==
DQAAAA==
DgAAAA==
AQAAAA==
This xml is an input source for method of mapframe denominate
mapFrame.ProcessFeatureInfo(xmlFeatures, bool, int)
and after I have a good highlights of features target and all work fine!!
My problem is regenerate this xml FeatureInformation nothing to effort a
singular spatial query for all features and recover id features with
alphanumeric query. this approach is more and more fast about computional
elaborate. I have just implemented this new approach: I can regenerate a
identical xml FeatureInformation, but if I give in input this xml at
mapFrame.ProcessFeatureInfo method the features is NOT highlights on map and
this is bad :(
What's my mistake?
The attribute "ID" of tag Layer must assigned in a canonical md5 checksum
(94e82a90-ffff-ffff-8000-000c2964d2f9) ? or a simple random number it's
equals?
and if this id must assigned in this md5 format, there is a method to
retrieve a random id layer from mapguide to regenerate this xml
featureinformation?
thanks in advance for your response
see U
Alessandro
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Highlight-features-on-mapguide-mapframe-with-alphanumeric-query-no-spatial-tp5282543p5282543.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100712/5e020395/attachment.html
