[mapguide-users] Subject: Best practices for running Fusion
	within frames
    Gordon Luckett
    gordon.luckett at arrowgeomatics.com
    Wed Jul 28 21:18:22 EDT 2010
Hi Warren,
I usually use iframes (and always call it the same thing  "iFrameMap")
I have found some issues with targeting some of the searches and had to
modify the code to find my "iFrameMap" within FUSION.
I make use of the \www\fusion\layers\MapGuide\MapGuideViewerApi.js file and
modify the lines that show:
var Fusion = window.top.Fusion;
to
var Fusion = window.top.iFrameMap.Fusion;
and that usually works really well.
I use the iFrameMap for the AJAX Basic version to and usually pass a
parameter to the JS files with VTYPE='AJAX' or VTYPE='FUSION' so I know what
viewer API to use.
Hope that helps.
Hey Jason,
Sorry, my bad...  I should know better to include version details...  It's
been a long day :-)
I'm using MGE 2011.
I was just more curious what others are doing wrt Fusion.  Are people using
iFrames, or Frames, or just building their wrappers?
Thanks.
Warren
On Wed, Jul 28, 2010 at 5:35 PM, Jason Birch <jason at jasonbirch.com> wrote:
Are you using a recent version? I think I saw some commits that change
the way widgets find their parent fairly recently (ie, could be bug).
On 2010-07-28, Warren Medernach <wmedernach at gmail.com> wrote:
> Hello all,
> I'm trying to use the Fusion viewer within a frameset and I'm getting
> some weird results using different browsers with 'out-of-the-box'
> functionality.
> For example, I have a Search function defined that works fine when I run
it
> in FireFox or Chrome, but in IE it fails to select and zoom to the object
> and a script error is thrown stating that it cannot find Fusion?
> Are there any 'best practices' or suggestions to using Fusion within a
> frameset?
> Warren M.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100728/5f377fbe/attachment.html
