[mapguide-users] Re: How to render MgMultiGeometry
Zac Spitzer
zac.spitzer at ennoble.com.au
Tue Jun 1 10:42:12 EDT 2010
I guess this is more a fdo issue, i am going to forward this on to the
fdo-users mailing list
silent failing and data loss is nasty, however esoteric it is
On 1 June 2010 23:15, Jonio, Dennis (Aviation) <DJonio at miami-airport.com> wrote:
> Zak,
> I did do just a bit more research. Yes, you dialoged on the issue back
> in Dec. 2007 and it looks to me that the _issue_ has gotten worse or, at
> best, stayed the same.
> >From the FDO API reference:
> The FdoIMultiGeometry class is a heterogeneous MultiGeometry type.
> >From the MapGuide API Reference:
> An MgMultiGeometry is a heterogeneous aggregate of one or more
> MgGeometry objects.
> I went ahead and tested the homogeneous _multi_geometry types with the
> SDF and KingOra providers, both seem to work well with all of the types.
> As far as heterogeneous geometry objects(point,line), (line,surface) go,
> as I noted earlier, KingOra adds the record but with a null geometry
> column. SDF does not even add the record. No error in the logs. Looks
> like Gunter is outa' luck.
> For my part I am not going to pursue the issue since we have no real
> practical use for those types of collections but I can envision them
> being useful for some.
> r,
> dennis
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
