[mapguide-users] Re: Setting Initial Map Selected object
Jose Cerrejon
gis at mapas-sll.com
Wed Jun 2 08:46:04 EDT 2010
Mike Adair wrote:
> doStartup: function() {
> this.mapWidget.deregisterForEvent(Fusion.Event.MAP_LOADED,
> this.doStartupFn);
> if (this.startup.spatialfilter != '' || this.startup.filter != '')
> var options = {
> layers: this.startup.selectlayer,
> geometry: this.startup.spatialfilter,
> filter: this.startup.filter,
> queryHiddenLayers: true,
> zoomTo: true
> this.mapWidget.query(options);
I'm using this code above in Mapguide.js with the last SVN Fusion repo, I
added in the initialize Function the next:
this.startup = {};
this.startup.filter = Fusion.getQueryParam('filter');
this.startup.selectlayer = Fusion.getQueryParam('selectlayer');
this.startup.spatialfilter = Fusion.getQueryParam('spatialfilter'); // I
don't have this param in the URL.
But two msgbox show me: Fusion Error: FATAL: invalidXMLDocument
I know i'm near from the solution. Any help? Thks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Setting-Initial-Map-Selected-object-tp5093643p5130579.html
