[mapguide-users] Services on Linux
Jason Birch
jason at jasonbirch.com
Wed Jun 2 22:22:48 EDT 2010
It depends on the flavour, but I think for most of them there is a
more structured approach of creating a control script and then
hyperlinking it from the appropriate linux run mode directory (or
something like that). The OS then runs the script with start/stop
parameters as appropriate. I built a script like this back when I was
experimenting with Ubuntu (look near the bottom):
http://wiki.osgeo.org/wiki/Building_Mapguide_on_Ubuntu_7.10_Server
On 2010-06-02, Andy Morsell <amorsell at spatialgis.com> wrote:
> While this may not be the best practice, you can add the Apache and MapGuide
> daemons to the Linux startup scripts in /etc/rc.d/rc.local. Your entries
> (for a standard install) would be something like:
> #Start MGOS HTTP
> #cd /usr/local/mapguideopensource/webserverextensions/apache2/bin
> ./httpd
> #Start MGOS
> cd /usr/local/mapguideopensource/server/bin
> ./mgserverd.sh
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> 47° 46' N 116° 49' W
> www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
> Sent: Wednesday, June 02, 2010 8:03 AM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Services on Linux
> A question to those that are more familiar with Linux.
> What is the standard practice for running something the equivalent as a
> service on Windows?
> I ask this question based on the recent email where the user had not started
> either Apache or MapGuide. This has happened several times so it would seem
> to me that we should be configuring installs to make these process run at
> startup.
> What is the best way to implement this and what kind of installer work would
> be required?
> Regards,
> Dave
> Dave Wilson, AEC IM
> CRT QA Analyst
> Autodesk Canada, Inc.
> 21st Floor
> 645 7th Ave SW
> Calgary, AB T2P 4G8
> Direct 403-538-3069
> Fax 403-264-1442
