[mapguide-users] MapGuide 2.2 on Ubuntu 9.10
Zac Spitzer zac.spitzer at gmail.com
Wed Jun 2 23:18:11 EDT 2010
devil in the detail :)
yup, alas raster is long known to be broken with mapguide os and gdal
http://www.otxsystems.com/community-initiatives/gdal-provider-initiative.html
z
2010/6/3 Pedro Venâncio <pedrongvenancio at yahoo.com>
> Hello Zac,
> As far as I can understand, just crashes the mapguide server, apache keeps
> running. I send the error logs of apache and mapguide, attached.
> I managed to realize that problems occur essentially with raster data. When
> working only with shapefiles, it gives no problem. The service run with
> good performance and without chashes. By creating dataconnections and layers
> of raster data, it always crashes.
> More evident is the fact that the Site Administrator can not load .mgp
> packages containing raster dataconnections. Others with just shp connections
> upload .mgp smoothly.
> I also tried connecting to wms and wfs servers, but it gives this error
> "Failed to identify properties read: An error occurred performing a
> WebClient request."
> Finally, I tried to connect to PostGIS, but doing Test connection, gives
> the message: "The remote server returned an error: (559) MgFdoException.."
> Thank you!
> --- On *Wed, 6/2/10, Zac Spitzer <zac.spitzer at ennoble.com.au>* wrote:
> anything in the error logs?
> was it apache or the mapguide server which crashed?
> what kind of datasources and dataset's where you using?
> 2010/6/2 Pedro Venâncio <pedrongvenancio at yahoo.com<http://mc/compose?to=pedrongvenancio@yahoo.com>
>> Hello Dave,
>> You are right, I was missing to start the mapguide server. Now it's
>> running!
>> I've been doing some tests and find some instability. Within few hours,
>> the server was down three times. Maestro also crashed several times. In
>> windows I rarely had stability problems.
>> I also could not make the connection to Postgis, like in 2.1 windows. Soon
>> I will test the connection to Postgis with this beta version on windows.
>> I'll keep trying!
>> Thank you very much for your help!
>> Pedro
>> --- On *Tue, 6/1/10, Dave Wilson <dave.wilson at autodesk.com<http://mc/compose?to=dave.wilson@autodesk.com>
>> >* wrote:
>>  Did you run the mgserver.sh script as well to start the server process?
>> You just run the Apache server.
>> Dave
>> *From:* mapguide-users-bounces at lists.osgeo.org<http://mc/compose?to=mapguide-users-bounces@lists.osgeo.org>[mailto:
>> mapguide-users-bounces at lists.osgeo.org<http://mc/compose?to=mapguide-users-bounces@lists.osgeo.org>]
>> *On Behalf Of *Pedro Venâncio
>> *Sent:* Tuesday, June 01, 2010 3:23 PM
>> *To:* MapGuide Users List
>> *Subject:* [mapguide-users] MapGuide 2.2 on Ubuntu 9.10
>> Hello everyone,
>> First I would like to congratulate the efforts of developers to make a
>> binary for ubuntu! This is excellent news, because long ago I had the idea
>> of migrating MGOS to ubuntu, and this is the opportunity!
>> I installed .deb packages of release 2.2 beta on a clean install of Ubuntu
>> 9.10 (on a VirtualBox virtual machine), all without problems, running the
>> script mginstallubuntu.sh. Then, I copied the phpviewersample-2.0 and
>> Sheboygan.mgp to their directories on ubuntu and tried to access the Site
>> Administrator, but without success. After running the command "sudo
>> /usr/local/mapguideopensource/webserverextensions/apache2/bin/apachectl
>> start", I've got access to the Site Administrator, but introducing the
>> credentials ID: Administrator  and Pass: admin, it shows this message: "Can
>> not establish connection ". Then I tried to access through Maestro, but
>> appeared the message of the image attached.
>> I appreciate the help and apologize for this (probably) basic questiony,
>> but I'm not an advanced ubuntu user.
>> Thank you!
>> Pedro
>> -----Inline Attachment Follows-----
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org<http://mc/compose?to=mapguide-users@lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100603/23976a4f/attachment.html
