[mapguide-users] Re: Commercial Map Service Help
LLEUNDD nuell at nicholsenvironmental.com
Thu Jun 3 14:11:37 EDT 2010
Thanks Jason -
I updated the Fusion as described here: http://svn.osgeo.org/fusion/trunk
and downloaded the latest fusion here: http://download.osgeo.org/fusion/
(fusion-2.0.0-RC1)
All the instructions for updating fusion were followed as per
http://svn.osgeo.org/fusion/trunk/INSTALLATION.TXT
I seem to be getting the same error though as mentioned above.
When I try loading the Sheboygan-m map from the sample folder without
changing the index.html or applicationdefinition.xml file, it loads just
fine.
If I update the index.html file and applicationdefinition.xml file as
instructed - the error comes up.  I am beginning to wonder if by replacing
the entire mapset contents with just the google and sheboygan-m as listed in
the instructions is incorrect.
I don't know enough about this - if someone can help I would be grateful!
Cheers!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Commercial-Map-Service-Help-tp5131790p5136253.html
