[mapguide-users] Mapguide OpenSource 2.2 backward compatibility problem
Zac Spitzer zac.spitzer at gmail.com
Fri Jun 4 02:53:58 EDT 2010
via the mapagent
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GETSITEVERSION&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer
there is an equivalent in the web api
On 4 June 2010 16:42, Bruno Scott <bscott at geomapgis.com> wrote:
> Hi All
> We have a quite big MGOS application deployed on hundreds of different
> clients
> Most of them use MGOS 2.1 or MGE 2010 SP1
> Some of them still use MGOS 2.0/1.2 or MGE 2010 / 2009
> They will migrate to MGOS 2.2 or MGE 2011 but this process takes time so our
> application
> have to live in a multi version MGOS/MGE.
> Now comes the problem with MGOS 2.2/MGE 2011
> We use extensively the MgException::GetMessage() fonction
> this function does not exist anymore because it is replaced by
> GetExceptionMessage.
> If we would only support MGOS 2.2/MGE 2011 it would be an easy fix.
> Search and replace... (260 occurances in 79 files....)
> But our code would not work in older MG anymore
> the error comes at compile time, so pretty hard to catch
> We are thinking of centralizing this call in a new internal function
>  string MgGetExceptionMessage(MgException mgEx,string locale)
>    //if MGOS 2.2 or MGE 2011
>    return mgEx.GetExceptionMessage(locale);
>    //else
>    //return mgEx.GetMessage();
> so this would simplify the code switching from 2.2/2011 to 2.1/2010
> We would need to detect the MG version in our application setup
> then switch this call from GetMessage to GetExceptionMessage
> What would be the safest way (for an setup program) to detect the MG
> version?
> Thanks for your answer.
> Bruno
> by the way, it would have been a lot easier for us if would have kept the
> GetMessage function
> for backward compatibility
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapguide-OpenSource-2-2-backward-compatibility-problem-tp5138292p5138292.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
