[mapguide-users] Re: Add layer from sdf
Zac Spitzer
zac.spitzer at gmail.com
Wed Jun 9 04:12:02 EDT 2010
you need to refresh the map via the browser to pick up the changes
On 9 June 2010 18:09, navya024 <navya.gudupi at gmail.com> wrote:
> Hi sir,
> based on your suggestion i wrote the following code to add layer from sdf.
> $resourceID = new MgResourceIdentifier('Library://new/dat.FeatureSource');
> $byteSource = new MgByteSource('E:\data\GFProp_Req.sdf');
> $data = $byteSource->GetReader();
> $resourceService->SetResourceData($resourceID, 'locations of points of
> interest', 'File', $data);
> $newLayer=CreatLayer($resourceService,$resourceID,$sessionId);
> <script language="javascript">
> alert("Hi");
> </script>
> <?php
> $map->GetLayers()->Insert(0, $newLayer);
> $map->Save($resourceService);
> catch (MgException $e)
> echo "<script language=\"javascript\" type=\"text/javascript\"> \n";
> $message = $e->GetMessage();
> $message = str_replace("\n", " ", $message);
> echo " alert(\" " . $message . " \"); \n";
> echo "</script> \n";
> function CreatLayer($resourceService, $bufferFeatureResId, $sessionId)
> try
> $doc = DOMDocument::load('bufferlayerdefinition.xml');
> $featureSourceNode = $doc->getElementsByTagName('ResourceId')->item(0);
> $featureSourceNode->nodeValue = $bufferFeatureResId->ToString();
> $layerDefinition = $doc->saveXML();
> $byteSource = new MgByteSource($layerDefinition,
> strlen($layerDefinition));
> $byteSource->SetMimeType(MgMimeType::Xml);
> $tempLayerResId = new MgResourceIdentifier("Session:" . $sessionId .
> "//Buffer.LayerDefinition");
> $resourceService->SetResource($tempLayerResId, $byteSource->GetReader(),
> null);
> $bufferLayer = new MgLayer($tempLayerResId, $resourceService);
> $bufferLayer->SetName("Buffer");
> $bufferLayer->SetLegendLabel("Buffer");
> $bufferLayer->SetDisplayInLegend(true);
> $bufferLayer->SetSelectable(false);
> return $bufferLayer;
> echo '<p>' . $e->GetMessage() . '</p>';
> echo '<p>' . $e->GetDetails() . '</p>';
> but the layer is shown on legend ?but it doesn't show on map?
> may i have done any mistakes?Please guide me
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Add-layer-from-sdf-tp5017702p5157244.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
