[mapguide-users] Re: Add layer from sdf
Zac Spitzer zac.spitzer at gmail.com
Wed Jun 9 05:19:55 EDT 2010
now you need to debug...
anything in the server error logs?
can you create that layer as a library resource and then can you view it?
ie make sure your layer works
On 9 June 2010 18:28, navya024 <navya.gudupi at gmail.com> wrote:
> Hi sir,
> Thanks for your patience.
> i refreshed the map using
> parent.parent.mapFrame.Refresh() using javascript still iam not getting the
> newly added layer on the map.
> May i done any mistake in the code.i rechecked it but iam not getting the
> mistake?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Add-layer-from-sdf-tp5017702p5157293.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
