[mapguide-users] Fusion ODBC Reproject
Berdel, Brian brian.berdel at mcmtrans.com
Thu Jun 10 09:21:39 EDT 2010
Hello All,
Having an issue with 2.2 and Fusion SVN and data reprojection.
I have an app setup that uses google and has multiple SDF layers, they all re-project on the fly with no issues to the Google projection, most of them are in Lat Longs.
However using an ODBC connection to a SQL Data base layer with Lat Longs the data does not seem to re-project.  I have set coordinate override...and the data does show up if I do not put it in this map and does not need to be re-projected.    No errors in the logs either, it just appears to not re-project when using ODBC.  Anyone else seeing this?
Thanks,
Brian
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100610/bf4e19e8/attachment.html
