[mapguide-users] spatial search problem
    ram282
    ram282 at gmail.com
    Mon Jun 14 08:26:22 EDT 2010
 I am trying to perform a spatial query.
 I click a point on the map and trying to find the features from a layer
called 'LandMarks'.
I have the google map as the background layer. All the layers(from SQL
server spatial) have the 4326 as SRID.
 I changed the CoOrdinate system in the map definition to support google
maps as background.
I am forming a polygon by creating a buffer around the point using
MgGeometry mgGeometry = mgPoint.Buffer(50, measure);
 The measure values is obtained from the function getMeasureValue()
specified below
But how could we specify the units? In the above line does the 50 means 50
metres ?
Can any one describe clearly about how to provide the correct measure value
while creating a buffer.
 I have used the MgFeatureSpatialOperations.Intersects and also tried with
MgFeatureSpatialOperations.Inside
But in the selectionXML there are no records obtained.
Instead of performing the spatial search, if I perform the non-spatial
search like
options.SetFilter("CityName='XYZ'");
 I am getting the records in selectionXML.
Below are the functions I have used..
 private void searchObjects(MgCoordinate coOrdinate)
 MgGeometryFactory GF = new MgGeometryFactory();
MgPoint mgPoint = GF.CreatePoint(coOrdinate);
MgCoordinateSystemMeasure measure = getMeasureValue();
MgFeatureQueryOptions options = new MgFeatureQueryOptions();
options.SetSpatialFilter("LandMarkPoint", mgGeometry,
MgFeatureSpatialOperations.Intersects);
MgLayer landmarkLayer = (MgLayer)map.GetLayers().GetItem("LandMarks");
MgFeatureReader reader = crossingsLayer.SelectFeatures(options);
 .... create siteconnection obj here ...
MgResourceService resService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
MgSelection selection = new MgSelection(map);
 selection.AddFeatures(landmarkLayer , reader, 0);
 string selectionXML = selection.ToXml();
selection.Save(resService, mapName);
 map.Save();
 reader.Close();
 private MgCoordinateSystemMeasure getMeasureValue()
 MgCoordinateSystemFactory coordSysFac = new MgCoordinateSystemFactory();
 MgCoordinateSystem cs = coordSysFac.Create(map.GetMapSRS());
//map.GetMapSRS() returns PROJCS["Popular Visualisation CRS /
Mercator",GEOGCS["Popular Visualisation
CRS",DATUM["Popular_Visualisation_Datum",SPHEROID["Popular Visualisation
Sphere",6378137,0,AUTHORITY["EPSG","7059"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6055"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4055"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Mercator_1SP"],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],AUTHORITY["EPSG","3785"],AXIS["X",EAST],AXIS["Y",NORTH]]
return cs.GetMeasure(); }
View this message in context: http://osgeo-org.1803224.n2.nabble.com/spatial-search-problem-tp5177202p5177202.html
