[mapguide-users] MGOS v2.2 Beta ! and SQL 2008. Again...
miansi AndreiSinelnikov at SierraSystems.com
Fri Jun 18 19:01:34 EDT 2010
Hello All,
Trying to use MGOS to pull data from SQL Server 2008. Using MS SQL Server
Spatial Provider.
Able to create Dataconnection, BUT:
1. On Local Preview tab in Maestro - attempt to run query results in error:
http://osgeo-org.1803224.n2.nabble.com/file/n5197257/2.png
2. While saving this dataconnection (which took like 5 minutes to do) -
getting following error:
http://osgeo-org.1803224.n2.nabble.com/file/n5197257/1.png
Erorr log has following records:
<2010-06-18T16:35:29> 	2144
 Success: Server started.
<2010-06-18T16:38:10> 	932	Fusion Viewer	::1
 Error: Session has expired or is invalid. Please log in again.
 StackTrace:
  - MgSiteServiceHandler.ProcessOperation() line 83 file
c:\builds\mg22win32\mgdev\server\src\services\site\SiteServiceHandler.cpp
  - MgOpAuthenticate.Execute() line 107 file
c:\builds\mg22win32\mgdev\server\src\services\site\OpAuthenticate.cpp
  - MgServerSiteService.Authenticate() line 709 file
c:\builds\mg22win32\mgdev\server\src\services\site\ServerSiteService.cpp
  - MgSecurityManager.Authenticate() line 224 file
c:\builds\mg22win32\mgdev\server\src\common\manager\SecurityManager.cpp
  - MgSessionCache.GetSessionInfo() line 175 file
c:\builds\mg22win32\mgdev\server\src\common\manager\SessionCache.cpp
I am able to create layer against dataconnection I just saved, but preview
shows no data at all.
Any ideas? Any alpha SQL FDO 3.5.x available for test?
Thank you,
Andrei
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGOS-v2-2-Beta-and-SQL-2008-Again-tp5197257p5197257.html
