[mapguide-users] Re: MGOS v2.2 Beta ! and SQL 2008. Again...
miansi
AndreiSinelnikov at SierraSystems.com
Mon Jun 21 16:39:55 EDT 2010
Thank you Jackie,
I do not care about spatial preview that much. I just want SQL FDO to work
and looks like it is not cooperating.
For example if I am trying to set map extents to the layer extents I see
following error:
http://osgeo-org.1803224.n2.nabble.com/file/n5206134/RoadSQL.png
I am using SQL Views with join to show features on the layer:
CREATE VIEW [geo].[vw_Road_Roadway]
WITH SCHEMABINDING
AS
SELECT
[base].[Id]
, [CategoryId]
, [SpatialStatusId]
, [LifecycleStatusId]
, [MaterialId]
, [AddressId]
, [DisplayId]
, [SpatialId]
, [ReportingId]
, Year([StatusDate]) StatusYear
, convert(varchar,[StatusDate],101) StatusDate
, [LocationDescription]
, [Geo]
, [Length]
FROM [dbo].[Asset] [base]
INNER JOIN [dbo].[Road_Roadway] [asset] ON [base].[Id] = [asset].[Id]
WHERE [base].[Geo] IS NOT NULL
AND [base].[SpatialId] IS NOT NULL
GO
but binding layer to the table instead of view not helping.
Basically - I am not able to retrieve spatial data from MS SQL and present
it on the map
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGOS-v2-2-Beta-and-SQL-2008-Again-tp5197257p5206134.html
