[mapguide-users] develop mapguide
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 24 23:41:46 EDT 2010
FDO is simply the (geospatial) data access layer (similiar to JDBC/ODBC)
MGP is the mapguide export package format which contains the
underlying xml layers, maps
and also optionally embedded file based formats like shp. It's
actually a zip file
what do you mean by map.shp ?
if you mean how do you create a map with mapguide using a shp file
1. create a feature source using a FDO provider pointing to say a SHP
file or database
2. create a layer which uses that feature source
3. create a mapDefinition which uses that layer
4. create a web layout which uses that map definition
thats about it
which authoring tool and mapguide version are you using?
On 25 June 2010 13:32, liely imoet <liely.244 at gmail.com> wrote:
> I'm studying develop webgis using mapguide, I have a difficulties to
> show the map.shp to the template that available, then I also still
> confuse about package.mgp and the function of FDO.
> I already success to show the map sample (sheboygan), but i am still
> confuse to show the map in shp format using mapguide.
> So i need your guide to solve my problem. Thank you before.
> lilik hanifah, Indonesia
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
